Commander A-Pillar Problems
Old Jul 28, 2007 | 02:37 PM
  #31
06CTDforAU's Avatar
Originally Posted by ptgarcia
I think someone else had a problem with their sensor in the Diesel Manor line also. Most likely it's not grounding well enough if at all.
I was thinking that too but I couldn't remember for sure. I realy think that the uppwer section of the line is anodized. If I'm thinking correctly (and haven't lost my mind completely ), an anodized fitting will interupt a ground signal. I'm getting too technical for myself.
Old Jul 28, 2007 | 02:50 PM
  #32
06CTDforAU's Avatar
Do you guys think it would be possible to put a ground wire behind the insulating washer as long as it is not touching the stud that the purple leads screws to? The washer is insulated so I am guessing it is grounded behind behind it otherwise it wouldn't matter if the purple lead touched it. Maybe that will work. All I can do is try......
Old Jul 28, 2007 | 03:30 PM
  #33
qzilla's Avatar
That will work if you can make certain it does not touch the post.
Ground will read 300 degrees so the gauge is working.
I have argued until I am blue in the face that the hot line does not ground the sensor but, I have been told I am an idiot about 20 times when I do that???
You might also just find a way to ground the entire line and that might be easier?
Old Jul 28, 2007 | 03:34 PM
  #34
vzdude's Avatar
DTR's 'Go to Guy'
^ That would be my vote! A jumper wire and a hose clamp won't look pretty, but will do the job just fine!
Old Jul 28, 2007 | 03:44 PM
  #35
06CTDforAU's Avatar
Don't matter if it doesn't look pretty; nobody will see it and that is what I'm gonna do! Of course because it is the easiest.....
Thanks for your help especially vzdude and qzilla. I'll back you up from now on Quad. I know for a fact that the cooler line from Diesel Manor is not grounded. I really do think it is because the connection fittings are anodized. That makes logical sense.
Old Jul 28, 2007 | 04:21 PM
  #36
qzilla's Avatar
Be careful trying to be locigal on the internet. You might get burned at the internet stake!!
Old Jul 28, 2007 | 05:52 PM
  #37
06CTDforAU's Avatar
Whatever you say Quad.....
Old Jul 28, 2007 | 07:21 PM
  #38
06CTDforAU's Avatar
I got it all working now. Thanks for all the input guys. I ended up putting a ring terminal on some 14 gauge wire and clamping it down to the sensor with a hose clamp. It doesn't look the greatest but works good for now. The important thing is that it is up and working.....
qzilla
Oct 4, 2006 09:59 PM
wagonhauler
Oct 3, 2006 11:15 PM
HDBeauty
14
Sep 22, 2006 06:58 PM
qzilla
25
Aug 26, 2006 12:23 AM
qzilla
28
Aug 5, 2006 09:58 AM
