Clutch Finally Installed
Old Nov 2, 2009 | 01:34 PM
Diesel87's Avatar
I finally got my clutch installed this last weekend. Everything went pretty easy. The only real problem I had was getting the input shaft to slide into the clutch. I would get the trans about an inch from the motor and the input shaft would not line up. Finally I got the trans close enough to get the bottom 4 bolts to start. I tightened the 4 bolts easily with a ratchet wrench and the input shaft finally popped into place. The clutch performs perfect. I noticed the shifter is harder to shift. Is this common? It is not extremely harder to shift, it just feels stiffer.
Old Nov 2, 2009 | 10:39 PM
CrazyCooter's Avatar
Yepper, it was a little harder and slower to shift for a while. I think it got better because I don't notice it anymore.
Old Nov 2, 2009 | 11:54 PM
bcfreighttrain's Avatar
ya x2
procrastinator
Oct 8, 2004 04:07 PM
hilclmr
Jul 18, 2004 01:49 AM
dodgediesel4x4
Apr 5, 2004 12:04 PM
FiverBob
Feb 2, 2003 02:00 PM
moss2904
15
Jan 17, 2003 08:25 AM
