Clutch Adjustable??
You can adjust the jam-nut on the pedal linkage but nothing after that. Also check to make sure the master cylinder is seated against the firewall, it only twists 1/4 turn into place on the bracket.
Did you replace your slave/master cylinder assembly when you put in your clutch. If I remember correctly SB recommends that if you have problems to change that if it has some miles behind it. May want to call them and inquire about it, they have been excellent to us when we call.
gunner7243
Feb 2, 2015 09:24 AM
MikeyB
Sep 12, 2013 12:21 PM
77machomopar
20
Dec 11, 2009 10:37 AM
greenworks
Jun 26, 2007 09:48 PM
