Cig lighter for gauge power
Old Sep 5, 2006 | 05:35 AM
jon05ctd's Avatar
I just read the post bout using the cigarette lighter power wire for the gauges.
Could I still use the cigarette lighter, or would it pop the fuse because of the gauges?
Old Sep 5, 2006 | 06:22 AM
RamWheelsBy4's Avatar
I used mine for a gauge power and it works fine with other items plugged.
Old Sep 5, 2006 | 07:10 AM
MikeyB's Avatar
Should have a 15 amp fuse for the cig lighter so there's plenty of power for the gauges and accessories.
MikeyB
Old Sep 5, 2006 | 09:58 AM
WUnderwood's Avatar
thats also where I ran my power from, no problems so far
Old Sep 5, 2006 | 11:00 AM
grdnw523's Avatar
where would you run your ground to?
Old Sep 5, 2006 | 01:43 PM
Most of my gauges and add on accessories are ground to the metal framework close to the right screw on the bottom of the access cover under the steering wheel. I think there was already a ground screw there for something to start with, but not sure. Five ground cables on that screw now. Did I make that confusing enough??
Old Sep 5, 2006 | 02:04 PM
WUnderwood's Avatar
thats where my gauges are grounded also
Old Sep 5, 2006 | 03:56 PM
LooseBoltsRob's Avatar
Just a tip for those using A-pillar pods...don't hassle with running power wires all the way to your cig lighter. On my 05 I had a fairly large connector on the A-pillar. I'm assuming it ran power to the dome light and auto dimming rear view mirror. There was a ground and a switched, ignition only (not accessory), power wire that I tapped into for my gauges. It was nice to use this wiring instead to avoid having one more pair of wires to fish down behind the dash. I don't remember the ignition power wire color....I think it was small red (not large red). The ground wire in the connector is black.
slickr1
May 30, 2012 08:27 AM
txdutchman
Feb 26, 2010 09:45 PM
VADSLRAM
Dec 24, 2008 02:12 PM
03CTDCO
Feb 28, 2005 05:35 PM
Maccandy
Jul 13, 2004 11:10 AM
