cfm manifold vs. smoke?
Old Jan 22, 2008 | 10:50 PM
07ctd's Avatar
i want to buy a cfm intake manifold for my 07ctd but does it cut down on smoke? i have a afe intake, smarty jr. and 4inch straight pipe. how much power and torque will i see with the cfm manifold?
Old Jan 23, 2008 | 01:46 AM
trik396's Avatar
No and none...
Old Jan 23, 2008 | 03:06 AM
Justice4all's Avatar
You won't see a difference in smoke. You'll get some horsepower down low when your not making a lot of boost. There are dyno results of a lightly modified Cummins making over 50 extra horses in the lower RPMs with one. However, the test truck had a grid delete too. Personally, I've seen good results with my CFM+.
Old Jan 23, 2008 | 06:30 AM
rogers259's Avatar
07CTD,
fill out your signature so we know what you've got.
I like the looks and what the CFM+ adds to the truck on the bottom end. but I personally think if you had other "must have's" you needed to get like gauges I'd get those first.
Old Jan 23, 2008 | 07:01 AM
MikeyB's Avatar
The CFM intake posted good results in the 1600-2200 rpm range. Best gain is 57.7hp/159tq over stock @ 1900rpms.
https://www.dieseltruckresource.com/...t=intake+elbow
MikeyB
Old Jan 23, 2008 | 08:03 AM
BIGDAN65's Avatar
helps some down low, egts are cooler, havn't noticed MPG improvement
Old Jan 23, 2008 | 08:48 AM
07ctd's Avatar
It Looks Like A Good Piece. I Think That Will Be My Next Buy
Old Jan 23, 2008 | 08:49 AM
trik396's Avatar
MikeyB
MikeyB, I just read some of that thread, don't have time to read it all yet. It doesn't seem remotely possible to gain that much power from 18" or so of any material... I could totally see 10, maybe 20 hp.... but how the heck...???
Old Jan 23, 2008 | 09:04 AM
BIGDAN65's Avatar
i thought the same thing trik, but when you get the stock one off you can see the restrictions, it is more responsive down low and the egts dropped which was my biggest reason for getting it
Old Jan 23, 2008 | 09:25 AM
Erik@LCD's Avatar
Hey, I did the testing and couldnt beleive it. I expected 0-30 HP or so. I would imagine that a stock truck might see that. With the common mods, they just seem to help a bunch. Every one we have installed has helped drop egts as much as 100degrees pulling a hill, so that alone is worth it!
Old Jan 23, 2008 | 09:29 AM
soulezoo's Avatar
DTR 1st Sergeant
I installed my CFM as a result of the tests Erik did. I was another skeptic. Now that it is on, I can say definitively it makes a difference. It is certainly not snake oil.
Old Jan 23, 2008 | 12:27 PM
trik396's Avatar
I've had the Banks horn on for awhile now. Not that I wanted it, but I needed a better intercooler (mine was plastic) and the tubing is larger than stock so I had no choice but to use it.
Old Jan 23, 2008 | 02:28 PM
rip 112's Avatar
If you see the inside the CFM+, you'll understand why. Its got a big opening and very smooth on the inside, and I've notice cooler egts, alot easier to cool the turbo down in the summer.
Old Jan 23, 2008 | 04:30 PM
223 rules's Avatar
Do you really need the heater grid or what do you do on the cooler mornings when you don't have it?
Old Jan 23, 2008 | 05:15 PM
rip 112's Avatar
Its supposedly not necessary to have unless you're further north in constant negative temperatures. I keep mine because it came with the truck and every little bit helps.
