cel Problem Smarty or Puck
Well last night was quite disapointing. I hooked to the sled and I pulled in 4th gear. My take off was great, Got my truck to weigh 8020lbs Set my puck to 60hp and smarty on 9. I thought this was going to be a full pull. Then At about the 200' mark The the truck fell on its face to about 2000rpm And check engine light came on
. The beginning Of the track I was running around 3700rpm But half track it dropped. Needless to say I only ran 227 and my truck would not rev past 2000rpm
.Since my smarty was still stuck in recovery it would not let me check my dtc's So my friend let me borrow his And it threw 2 code The same as for when I hit the top speed with old smarty sw. Map sensor voltage to high and turbocharger overboost condition. Is this the smarty or the power puck?????????? Need help!!! My boost was at 48psi or so and, rail pressure around 26,500psi I don't get this and need help/answers. BOb's revovery software never worked on my truck. So I'm going to download knewest sw and see what happens. I do know with the puck in the off position IT will still throw these codes because I was on a dyno last weekend. Please help
Well I figured it out. Although the power puck makes power it is not a high peformance item, More or less a piece of junk. It is the reason why my jruck defuel at anything higher than 42 psi of boost for a moment of time. and also "YOU CAN NOT GO OVER 110 WITH IT OR IT WILL THROUGH CODES" I hit 134 today code free. I just need to know iif the mp-8 or any other pressure only boxes will work over 110.
MrSuzuki
Jun 16, 2009 12:23 AM
boaterman
Oct 15, 2008 10:44 AM
Hillbilly Delux
Mar 20, 2008 05:01 PM
BIGDAN65
16
Jan 23, 2008 10:02 PM
