Carli Suspension Air Bump Kits.....
Old Aug 28, 2007 | 04:35 AM
bob4x4's Avatar
Originally Posted by Cowhand
Long travel air bags and hydro bumps are incompatible at this time....
We have discussed it
Bob
Old Aug 28, 2007 | 04:36 AM
bob4x4's Avatar
Originally Posted by Stacked97
Wheres Bob4x4 with the pics of them on his truck!?
Here you go...........
Bob
Old Aug 28, 2007 | 04:41 AM
bob4x4's Avatar
Originally Posted by jrussell
Those are nice, but how many of us actually race/jump/baja our trucks enough to need them?
The funny thing is Sage has designed them to work even on a stock truck.All the guys that complain because their trucks bottom too easy could use them.
Using the bumps you can use softer springs and lighter shock valving with less bottoming out risk
Bob
Old Aug 28, 2007 | 12:27 PM
Cowhand's Avatar
Bob
I don't doubt it........
IIRC, the can and the upper bag mount go in the same place
Old Aug 28, 2007 | 12:58 PM
cquestad's Avatar
Who has bottomed their rar anyways? My bags eventually hit...lol.
Old Aug 28, 2007 | 02:37 PM
bob4x4's Avatar
The bags work great off roading,I had about 2psi in them when we went down for the Baja 500,the truck bed was loaded to the gills to take the stress off the lesser vehicles in our caravan.The road out to Mikes Sky ranch was a blast at speed even with a bed of of supplies and firewood.Rock crawling they like just as well.
Bob
Old Aug 28, 2007 | 02:46 PM
ptgarcia's Avatar
I forget, what weight are those bags rated at? Was it 1000 lbs each?
Old Aug 28, 2007 | 02:51 PM
Halibrand's Avatar
Bob
Bob, I heard that unless you are really bashing on the cans it kind of kills the ride on these suspensions: I guess a medium sized bump that would normally not bottom out and feel normal will now strike the bumpstop giving a harsh feeling.
Any truth to this in your bashing and thrashing?
Im thinking Id rather feel the can getting bumped than steel on steel pounding. But also looking at your pics, you seem to have atleast 4" between the can and the striking pad on the frame, so it seems it would take a pretty good hit to get the bumpstops engaged.
Old Aug 29, 2007 | 06:08 PM
Cowhand's Avatar
Pauly, IIRC the bags are good for 1500# each....
Old Aug 29, 2007 | 07:17 PM
jrussell's Avatar
Does that mean you can't really use them for heavy towing? If so that would really ruin my day.
Are they available for sale yet?
Old Aug 29, 2007 | 07:44 PM
Danderson's Avatar
Northstar camper and Carli long travel bags.
I've got 'em on mine.(see sig.) Carli's website has been updated to include these. Sage originally filled mine to 50 psi,which raised the back up so much we deflated them to 35psi. I've got the Lorenz 2" lift springs up front. I could drop them again to 25psi probably and maintain a level truck. These have a softer ride then the Ride Rites with extended travel,but still control the sway well. Sean Lorenz also swapped out my 2.25's for some others with stiffer rebound and compression which helped enormously. Bob can chime in on his towing experiences with them.
Old Aug 29, 2007 | 09:49 PM
Cowhand's Avatar
I tow an 11K trailer (900lb tongue weight), plus a quad, coolers, firewood, etc. in the bed with about 35psi in the bags......
Old Aug 30, 2007 | 12:14 AM
ptgarcia's Avatar
Thanks Conrad. That's plenty for what I need them for.
Figure 3000 lbs plus what the springs can carry. So for most they will be sufficient.
They are available, and are selling for $850.
Clmsnow
16
Nov 27, 2009 03:57 PM
mtnman006
24
Sep 8, 2009 03:14 PM
silkywoods
Dec 8, 2007 04:23 PM
royta
Nov 6, 2006 08:19 AM
LCH
Oct 26, 2006 05:10 AM
