Can I fit 35" tires on my truck? Need input...
Old Mar 5, 2008 | 10:26 AM
RedRacer44's Avatar
I've searched this topic and read LOTS of threads but I still cant get a clear cut answer with my setup...
I have the Gear Alloy 711 MB 18" wheel...its an 18x9 wheel. I cant find the backspacing specs on the wheel though.
I also have a 2" leveling kit on the truck as my sig shows...
I'm wanting to get the Nitto Terra Grappler in size 325/65/R18...which is basically a 35x13.00 tire. Another tire option I'm looking at is the Toyo Open Country M/T that is basically a 35x11.50 tire...
Any ideas guys?
Old Mar 5, 2008 | 10:32 AM
tcr's Avatar
tcr
No, gear wheels that I've seen stick way out. You'll have rubbing issues on the rear of the front fender.
Old Mar 5, 2008 | 10:44 AM
RedRacer44's Avatar
Dang...alright...well back to 33"s we go!
Old Mar 5, 2008 | 12:02 PM
supercharged_hp's Avatar
The Gear Alloy 22" wheels I'm looking at have perfect offset. Either 5.5" or 6" depending on which one I order.
Best bet is to measure it or do a search and see what you've got.
Old Mar 5, 2008 | 12:25 PM
RedRacer44's Avatar
I looked on a couple of websites....
The only "measurement" I keep finding is the Bolt Pattern, I think? It says: 8x6.5, 5x5.5, and 6x5.5....is the 2nd number the back-spacing?
Old Mar 5, 2008 | 12:30 PM
RedRacer44's Avatar
Ok, here is the most detailed description of my wheels. Anyone got an idea which wheel would work...if any? You will probably have to click on "18" to show the 18 inch wheels...
http://eastcoasttires.com/wheelbrand...Black-Finish/#
Old Mar 5, 2008 | 12:40 PM
ptgarcia's Avatar
You have a +10mm offset, which should be about 5.5" backspacing. 35's should work. You may get a slight rub on the plastic inner fender on occasion, but I don't think you'll have any serious issues. I'd do it.
Old Mar 5, 2008 | 12:43 PM
RedRacer44's Avatar
I just ordered tires from my local tire shop....but I can cancel/change my order....
Just hate to order them and then they wont fit....
Old Mar 5, 2008 | 02:28 PM
enafzige's Avatar
Check out this website...it's the best thing I've seen for getting an idea of what will fit. Put in the stock tire/wheel size on the left, and the wheels/tires your wanting to change to on the right.
http://www.1000rims.com/rt_specs.jsp
--Eric
sho_shane
Mar 3, 2013 09:52 PM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
VikingDiesel
47
May 11, 2007 12:52 AM
sakisaki400
23
Dec 31, 2006 10:17 PM
xyzer
Jun 22, 2006 07:44 AM
