In cab tuner for 05
In cab tuner for 05
Which in cab tuner would you guys recommend. Id like one with a monitor. Is there any other options other than the Edge or Bullydog? If not which of those two are recommended. The only other upgrades planned for the truck is a cat back exh, and either the S&B intake or AFE. Thanks for the advice
Edge Juice/Attitude. Anything you put on your truck they can tell. With the exception of Smarty and maybe MP8. As far as I know. I guarantee they can tell if you put BullyDog on...they may overlook connection points where the Edge or maybe a TST connects to the wiring harness, but youd have to keep in mind the mounting point for the box. Typically its held onto the fuse panel cover with Velcro...
If you get a quadzilla box and take it out they cannot tell it was there. It plugs into factory harnesses and doesnt splice anywhere. It also has to be mounted inside the truck so no velcro. I have been to the dealer a couple times with no problems after removing the box.
HelenaTDI
May 15, 2015 10:11 AM
banyon
Apr 10, 2014 08:19 PM
TurboPirate24v
Dec 31, 2003 11:12 AM
