Bullydog stuck on vehicle
Old Sep 10, 2007 | 07:00 AM
gpshemi's Avatar
I won a Bullydog Outlook combo off Ebay for $285. The outlook paperwork says it's for an 03-06 Cummins, so that's ok, although I haven't tried it yet. The Triple Dog Power Pup says it's for Ford, Dodge, and Chevy. However, the programmer seems to be stuck on Powerstroke 6.0L. There's no main menu for a way to get back to pick a different vehicle.
I downloaded the Agent from Bullydog and it updates fine and check sums fine. So it's on the latest program. Although I will add that Crazy Larry wouldn't download and told me to try back later.
Anyone have any ideas what's going on with it. I wrote BullyDog, but it'll probably be some time before they get back with me on it I bet.
Thanks,
gpshemi
Old Sep 10, 2007 | 07:04 AM
StrokeThisCTD's Avatar
if you go to install download it should ask you what vehicle you want it on
Old Sep 10, 2007 | 07:15 AM
gpshemi's Avatar
It doesn't. The agent reconizes the programmer and says it needs an update. Then you click and it starts the update. No choices to be made with the agent. It already knows it appears.
Old Sep 10, 2007 | 09:54 AM
gafirefighter's Avatar
strokethis is talking about when you download it to the vehicle it should ask you which vehicle it is going on not when you are updating the bdtd on the computer.
Old Sep 10, 2007 | 10:02 AM
JCLeary's Avatar
The first time I installed the Bully Dog I found it confusing.
As stated above, once you plug it in to your OBD port and choose to install, it should ask what type of truck it is.
Old Sep 10, 2007 | 10:08 AM
gpshemi's Avatar
When I plug it into the truck it give the same menu picks as when it's hooked up to the computer. It says something like "load powerstroke 6.0" and blinks to "yes?" If you say no, then it flashes for a second and then asks you the same thing again.
Old Sep 10, 2007 | 10:09 AM
gpshemi's Avatar
So you think if I goto download it will ask me what truck? I hope it doesn't try to load the powerstroke information into the truck. Shesh....
Old Sep 10, 2007 | 10:13 AM
Bud Kunz's Avatar
gpshemi,
When you first plug it in....does the splash screen say Triple Dog?
After that what screen does it go to?
Does it say Main Menu on top with the first option being Install Download?
Bud
Old Sep 10, 2007 | 10:20 AM
gpshemi's Avatar
I'll look again tonight. It seems to me that it flashes the triple dog logo, then goes to the first menu with the first pick being download. However, at the top of the screen it says powerstroke 6.0L and is asking you to it yes. Do they all default to that until you hit download.
See...the reason I'm hung up about this is becuase of what the auction stated. It said it was a return becuase it didn't read the correct truck on the monitor. However, it didn't seem to indicate what monitor. I think it could just be confusing really. The thing looks brand new with wrappers on everything, wire ties, and screen protectors in place. I'm sure it's new.
Last edited by John_P; Sep 10, 2007 at 01:07 PM. Reason: Posting Advertising (Non-Vendor)
Old Sep 10, 2007 | 10:44 AM
Bud Kunz's Avatar
Yes. They all come defaulted into the Ford code. However, when you select install download a select vehicle screen should come up that gives you the option to select another vehicle. You should be able to select Cummins 5.9L at that point and then the downloader resets into the dodge software. Let me know what happens.
Old Sep 10, 2007 | 11:48 AM
gpshemi's Avatar
ok. I'll check it out tonight. I was afraid to hit download for fear it would try to cram powerstoke info in the truck. I hope that can't happen really....
Old Sep 10, 2007 | 11:58 AM
Bud Kunz's Avatar
Do it with the key off. This will protect your truck. With the key off it won't see anything that happens to get transmitted on to the can bus. After it says cummins on the main screen then turn the key on when prompted.
Old Sep 10, 2007 | 12:13 PM
gpshemi's Avatar
Awsome. Thanks Bud. I'll work on it more tonight. Wife has a hunny do list though for me. Not sure how much time I'll get to play.
Old Sep 11, 2007 | 04:16 PM
gpshemi's Avatar
OK. At first I got it plugged into the truck and went down to "Read DTC's" and it just says "loaded". Nothing else happens. If you hit the back key it shows. "Enter Password 1111 6734". However, if I go to Download and press Y, then it comes up with the truck options. So it appears to work. Haven't installed it yet. I have to take it into the shop for a fix first. No since it putting it in and then having to take it back out. I'll just leave well enough alone. Especially cuz this dealer seems ultra sensative about any kind of mod, yet at the same time drives a dealer 2500 all customed out. Go figure.
wheelo90
Off Road / 4x4
67
Feb 19, 2011 01:55 AM
LilBigd02
17
Feb 28, 2010 09:22 AM
Baja
Jan 29, 2008 08:17 PM
Mike D
Jul 13, 2007 07:23 AM
mestdagh
Feb 1, 2005 09:43 AM
