bullydog can't fix my problem!!!!!!!
Old Nov 26, 2007 | 10:35 AM
  #46
06RED-BARON's Avatar
Originally Posted by Bud Kunz
It could be from the tranny or it could be a calibration issue. Sending you a pm.
Right on bud thanks ....Chad
Old Nov 26, 2007 | 10:52 AM
  #47
choppers555's Avatar
hey guys and thank you bud for coming threw, i just could not wait any longer it is my daily driver. I took the truck into the dealership this morning and they re-flashed my TIP. You are exactly right BUD, about the calibration stored in the TIP. You are the man, i wish i would have had more time to talk to you, cause it did cost me 68 dollars from dodge for them to use ther STAR scan. I re- installed the bullydog this morning and everything is working GREAT!!!!!!!!!!!!! thanks again for the help from everyone.
OH 06RED..... i called ATS this morning about the tcc/ od solenoid code p1740, cause my truck is getting the same code. they told me that about 25 out of 100 trucks are getting that code. they said they are working on the issue right now and they should have it resolved in 3 weeks. he told me to give them a call in 3 weeks and they will have the silution. hope that helps RED.
Old Nov 26, 2007 | 11:00 AM
  #48
Thats awesome chopper much appreciated, i also have bud looking into it aswell. If he can fix that issue ill let ya know what to do to recitfy that problem. Im glad you have fixed the other issue right on. thanks. Chad
Old Nov 26, 2007 | 04:21 PM
  #49
TX_Diesel's Avatar
one of the guys here had mentioned that he did not think the manual shift
4 wheel drive had a transfer case motor. if he is right, what i think may have happened when bullydog tried to re-program my truck they programed the ECM for a electronic shift 4wheel drive. i think this is the reason that light and those codes are showing up. the truck thinks it is an electriconic shift when it really is a manual shift. does this make sense?
Glad to hear you got it all fixed Chop. I knew it sounded kinda fishy when you said you had a manual shifter and they told you, you needed a shift motor....
Totallyrad
Jul 19, 2011 07:41 AM
LilBigd02
17
Feb 28, 2010 09:22 AM
Rickcher
Jul 13, 2009 01:22 PM
Stainless
Feb 5, 2008 11:01 AM
03CTDCO
Oct 4, 2004 05:47 AM
