Bully Dog Outlook OBD-II Cable/Connector
Old Feb 17, 2008 | 07:04 PM
D45's Avatar
D45
Can the Outlook be used without the OBDII cable/connector or is this part a vital item in monitoring the various engine information and data....
THANKS!
Old Feb 17, 2008 | 07:34 PM
SmokinDodge12V's Avatar
I was wondering the same thing, I think it gets the info from the data link conector under the hood but gets power from the OBD connector. I have an outlook but dont use it because I dont like having it hooked into the OBD.
Old Feb 17, 2008 | 07:37 PM
preloader's Avatar
Whats wrong with having it hooked up constatly?
Old Feb 17, 2008 | 07:42 PM
Billm2004's Avatar
no it has to be hooked up all the time, at least if you want to use it as a set of gauges. if you unplug it it turns off
Old Feb 17, 2008 | 08:11 PM
D45's Avatar
D45
By this you mean the ODBII cbale has to be plugged in, at all times, to the ODBII data port.......correct?
And, without the OBDII, the Outlook will not function or read any info?
gpshemi
3rd Gen All Products
0
Jul 19, 2015 06:25 PM
Hercules
Jan 22, 2013 03:44 PM
RDM16CTD
Jul 22, 2010 04:40 PM
