boost fooling
Naw man. you already have a connection from your juice plugged into your MAP. The quadzilla does the same thing. Male end to female and female to male. I have a friend with an 06 that put the juice with attitude and bought a boost fooler after i got mine and its not compatible. you already have it.
Just because it has a MAP plug doesn't mean it boost fools. It alters the signal to the pcm from the MAP sensor so that the pcm sends more fuel to the injectors. This has nothing to do with boost fooling. An MP-8, Power Puck, Etc. plugs into the MAP but doesn't boost fool. I've not seen an edge boost 45 lbs alone like other chips will with a quad boost fooler. Why would the edge have boost fooling when it is designed to defuel to prevent high levels of boost?
Well when I called TS Performance they said the MP8 does not boost fool. It is pressure ONLY. I put twins on an 05 a while back and until he got a boost fooler he was throwing an overboost code as well, with an MP-8 on the truck. Just because something is hitting 45 lbs at peak doesn't mean it's boost fooling. My truck with the Quad X2 that is not boost fooling right now due to a software flaw, will peak at 47 lbs, but will not sustain it. When I had my old Quad box that was boost fooling, it would sustain 45 lbs. Your wastegate can only flow so much, and with enough fueling, you can move enough air to make 45 lbs peak boost with the wastegate open.
MP8 Dosent Boost Fool.....Adam Knows what he's talking about, The Assulting drive pressures will increase the knowledge of the Companion CPD Module and the drive pressures also increase the ability to sight the of the Boost pressures....As long as your drive pressures are below 500 KPA PSI Ratios of deliverence through-out the camel abbits.....Will keep the boost fooling active on the mp-8 wobbler shaft...its next to the muffler bearing and kevin kline aftershave......
In reality... Adam's Right....The rest is Just Kidding
Well then TS needs to get together and have a meeting so they are giving the same information to everyone.
Read this thread. Even Quad says the Juice boost fools and he's tested just about everything.
https://www.dieseltruckresource.com/...d.php?t=147898
