Boost fooling?
Old Feb 1, 2007 | 07:47 PM
jb903's Avatar
97360 im having kinds the same issue with the triple dog and boost fooler. my boost goes to 25 then creeps real slow to 40-45 then drops again to 35. i have downloaded the 2.2.7 version and this has helped alittle but it still creeps too slow. i have to roll into it at like 75mph and by the time i get to 100mph its at 45lbsand stays then starts to drop. i have checked all the boots and they are fine. im thinking its the triple dog cause i have the edge and i hit 40lbs instantly.
Old Feb 1, 2007 | 09:25 PM
973604x4's Avatar
Your issue is the triple dog programming. I experienced today with Boarbuster's truck that sometimes the boost fooler will quit working...but change levels on the triple dog and it works again. Go figure!!! This is not a Quad problem, this is a bullydog problem.
We found my problem......we think.
Like I first guessed, i am not getting enough fuel. We found out today the Glacier wasnt running. Checked the fuse....fuse blown. Replaced it...blew another fuse. Theres a short somewhere on my power wire from the pump to the battery....i'll be hunting it down Sunday.
also confirmed i have 2 tie rods out too.....
Thanks to WUnderwood, Boarbuster, and johnny (i forgot your dtr sn) for coming over and helping diagnose today.
Old Feb 1, 2007 | 10:23 PM
jgiachino's Avatar
Congrats on finding the issue / solution!
Old Feb 2, 2007 | 06:27 AM
MOJO1's Avatar
I could use some boost on my truck seems low to me.19 PSI boost all i see no matter what setting im on whats up with this? Is the MP-8 not boost fooling or do i need to redownload the BDDL?
THANKS
Old Feb 2, 2007 | 09:49 AM
973604x4's Avatar
THANKS
I might be crazy...but i stacked Crazy Larry + TS MP8 + Quadzilla boost fooler. It would haul butt and i would see over 40psi on the stock turbo.
19psi is bad...very bad. You should see around 30 stock!!!! Call TS, see what they say. They claim to be experts with the Crazy Larry/MP8 stack.
Old Feb 4, 2007 | 06:26 PM
973604x4's Avatar
found it...we think.
Walbro has a short in it....calling Glacier tommorrow.
I didn't know the truck would run as well as it does with NO lift pump at all!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
goose2w1
Jul 23, 2008 10:49 PM
vwjunkie53
19
Nov 9, 2007 02:27 PM
eastmentCTD600
Jan 12, 2006 11:43 PM
wap
Aug 21, 2005 03:39 PM
