Boost Fooling??
Old Jan 12, 2006 | 05:58 PM
eastmentCTD600's Avatar
Question Boost Fooling??
What do the box manufacturers mean by boost fooling?
Does it change the map sensor input to the computer and actually increase boost pressure, modify when the wastegate operates, or does it fool the computer into thinking the boost is higher than actual and make the computer add more fuel?
Thanks in advance.
Eric
Old Jan 12, 2006 | 07:03 PM
swansong04's Avatar
Thanks in advance.
Eric
well i am no expert and maybe one the guru's on this site might wanna chime in .. but what boost fooling or fuleing or low boost fueling is the box/programmer tells the computer the the turbos making boost (but really isn't)so in turn the ecm is bring on fuel .. when you have a lot of low boost fueling the truck seems to make alot of smoke .. anyway that is said in lame mens terms so maybe somebody else can add to that ..
Gary
Old Jan 12, 2006 | 07:19 PM
Ph4tty's Avatar
When you're getting more boost than the ecm allows the ecm will defuel, so a boost fooler allows you to run more than stock levels of boost without throwing a code nor defueling.
Old Jan 12, 2006 | 08:03 PM
leaddog's Avatar
Who uses boost fooling? (bullydog,Quad,etc.)
Old Jan 12, 2006 | 08:51 PM
swansong04's Avatar
The quad xzt box i used to run used boost fooling .. it's a 65 hp box and could make 44 psi at wot ..
Old Jan 12, 2006 | 08:57 PM
underwoodtransp's Avatar
I think you are looking at this the wrong way.. If you tell the computer you are getting more boost than you actually are you will in the long run loose boost pressure..
Boost fooling is telling the computer you have less boost than you actually do so that the computer will give more fuel and let the turbo push more pressure also. Fooling is the only way that "boxes or modules" adjust boost pressure. Only programmers change the parameters in the computer to "allow" more boost.
Old Jan 12, 2006 | 11:43 PM
hognutz's Avatar
my understanding is it tells the computer there is less boost than there is becasue the factory computer is going to cut the boost off at a set point.
this wil alow boost levels to go higher.
the down side is a box that made more boost than certain parts of the sytem would handle or not handle forever.
then again I am no expert on the subject. newbie to diesels. one step above posting "why is my truck dieseling" ha ha
goose2w1
Jul 23, 2008 10:49 PM
vwjunkie53
19
Nov 9, 2007 02:27 PM
morkable
Oct 4, 2006 07:11 AM
wap
Aug 21, 2005 03:39 PM
