"Boost Fooler" Question
Old Dec 26, 2006 | 11:12 PM
Mr Bee's Avatar
Does this device leave a footprint for the dealer to find if it is removed before the visit?
Old Dec 27, 2006 | 09:09 AM
goodeyesniper75's Avatar
im 99.9% sure that is doesnt but i dont want to lie to you so i would wait for someone who 100% sure.
Old Dec 27, 2006 | 09:17 AM
jrussell's Avatar
It will allow for more boost than stock. Won't the dealer be able to read the max boost level(s) stored in the ECM and see it's much higher stock?
Old Dec 27, 2006 | 09:42 AM
Sixpack73's Avatar
I would think not, as the whole 'fooler' concept means the ECM thinks it is running normally.
Old Dec 27, 2006 | 10:23 AM
jrussell's Avatar
Lol! Guess that's what happens when you post before
Not to hijack, but does anyone know for sure what parameters are stored in the ECM like that (if any)? I assume things like boost, fuel pressure, fuel quantity, and timing can/will be stored if the default maximum values are exceeded?
I thought there was a post a couple years ago on Pirate4x4 from a guy who blew his CTD while towing with a box? If I remember correctly, he removed the box and the dealer still voided his warranty because they could see the max boost stored in the ECM was higher than the stock W/G would allow. Anyone remember this or have a link?
Old Dec 27, 2006 | 04:54 PM
Mr Bee's Avatar
Great info from all, but if the boost fooler tells the ecm a "LIE" that would be all that is documented. It would have no way of telling actual PSI. Again, if I am correct how it works the computer thinks the boost is say 30psi when it is actually 38psi. But I could be wrong...
Old Jan 5, 2007 | 09:08 PM
shepherd's Avatar
Correct-if The Boost Fooler Allowed The Ecm To See 38 Psi, Then It Did Not Do A Good Job Of Fooling.
Old Jan 5, 2007 | 09:11 PM
Speed Shift's Avatar
100% sure......(if it does just sue me)
Old Jan 5, 2007 | 11:36 PM
KBennett's Avatar
If the ECM saw high boost numbers then it would throw a code. If you are not seeing any codes then the ECM probably thinks all is well.
Old Jan 5, 2007 | 11:52 PM
robert97dodge's Avatar
Will the boost foolers help keep EGT's down? It make more boost which make more air flow which should make cooler EGT's right??
Old Jan 6, 2007 | 01:11 AM
973604x4's Avatar
Yes. Yes.
But more air is not always cool air. You will see a reduction in EGT's and higher boost with a boost fooler, similar to an aftermarket turbo....but you will never see the performance of a bigger turbo with the boost fooler because it simply can't move enough air. Theres a point where the stock turbo reaches maximum efficiency range.
Old Jan 6, 2007 | 02:04 AM
jwb600's Avatar
Originally Posted by 973604x4
Yes. Yes.
I fully agree with you on this statement
Killdmycobra
Nov 12, 2010 05:15 PM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
Rollin' Smoke
23
Jun 26, 2007 09:04 PM
GTSDave
Jul 8, 2005 09:06 AM
