bolt pattern
Old Feb 24, 2009 | 03:15 PM
BigGameJames's Avatar
Question bolt pattern
anyone know what bolt pattern i need for my truck?
8 on 170?
8 on 200?
8 on 6.5?
I was going to get the kmc ambush but 4wheelparts.com doesn't have them out with my bolt pattern until may
thanks in advance
Old Feb 24, 2009 | 03:19 PM
Mcmopar's Avatar
8 X 6.5
darn too short error message!!
Old Feb 24, 2009 | 03:31 PM
ok here it is
Rim
KMC Ambush
Part number: W/PXD44189080706N
18X8, 8 on 6.5 Bolt Pattern
* Backspace 4.76 in.
* Max Load = 3200lbs
* Finish = Matte Black
* Hubcentric = No
* Offset = -6 mm
Tire
Pro Comp Xtreme All Terrain Radial
Part number : PCT5801237
37x12.50R-18, Pro Comp Xtreme All Terrain Radial
* Load Range E
* Max Load 3970
* Tread Depth 23/32
* Overall Diameter 36.8 Inches
* Black SideWall
* Sidewall Construction= Tri-Ply
* 40,000 Mile Tread Wear Warranty
This is off of 4wheelparts.com by the way
Thanks in advance!
Old Feb 24, 2009 | 03:32 PM
ok here it is
Rim
KMC Ambush
* Hubcentric = No
* Offset = -6 mm
Tire
* Load Range E
* Max Load 3970
* Tread Depth 23/32
* Black SideWall
or does is need to be the 37x13.50R-18?
Thanks in advance!
Old Feb 24, 2009 | 03:47 PM
anyone?
haha
Old Feb 24, 2009 | 07:40 PM
Mcmopar's Avatar
Originally Posted by BigGameJames
anyone?
haha
Anyone what??
Old Feb 25, 2009 | 02:12 AM
will those rims and those tires fit together?
Old Feb 25, 2009 | 02:51 AM
tmacie's Avatar
That rim is only 8" wide, better stick with the 12.50's. 13.50's might get tough to mount.
Old Feb 25, 2009 | 10:31 AM
Thank you
I'll keep looking
midwestdually
Jul 4, 2005 01:10 PM
lt11le
Mar 14, 2005 12:36 PM
midwestdually
Dec 21, 2004 07:09 PM
Jeff K
Mar 3, 2003 06:03 PM
crossy
Nov 8, 2002 05:05 AM
