Air Leak - Compressor Workin OT - Help
I've been having to refill the air tank from about half tank 1 - 2 times a day. At this rate the compressor is going to live a short life. So i've been thinking about changing out the air lines/connectors.
Right now i have the 3/8 OD plastic air hose, and ribbed slide in (the hose) fittings that came with the Viair kit. I believe that this is where the air is leaking from
I'd like to swap out the plastic hose and fittings to a rubber hose with the fittings already attached like in the picture below, but dont need 50' of hose. Does anyone know where i can get 3' or 4' sections of hose with these fittings, or have a suggestion on how to keep from losing so much air from my current set up?
Sorry if i'm beating a dead horse... I've searched hose...air hose...air leak, but could not find anything on this subject...
Any and all suggestions welcome!!
Thanks!
Thanks!
Thats the only place i can think of that it might be leaking from (fitting not snug enough on the hose??...) other then the tank itself having a leak of some kind....
I took all the connectors off the other day, rewrapped all with tape, and reconnected.... I also felt around the tank to feel for a leak but couldnt find anything.....
That fitting appears to be a push lock fititng for rubber hose...not plastic!
Go get quick snap or flared compression fittings for the plastic/poly line you are using...
Semi Parts/Dealers have a huge assortment handy for their brake lines.
mainer
Oct 8, 2005 07:24 PM
