Big CP3 more power?
Old Jun 20, 2008 | 06:53 PM
  #31
12valve's Avatar
i see the same RP, removing the smarty! (stock, just running on the flux 2's)
Old Jun 20, 2008 | 08:54 PM
  #32
coreydr2003's Avatar
Originally Posted by Sloverado
Seem kinda low. I have dual pumps now but with about the same setup (Flux 3.3 and Floor It pump) I could still hit over 25500 no problem last year.
I have spicked the gauge at 30k and its no problem aT WOT. Sloverado knows this about these stg3 pumps
Old Jun 20, 2008 | 11:09 PM
  #33
Sloverado's Avatar
That I do. I have worked alot with Floor It and BAM Diesel. Floor Its pump are bars above the rest.
Old Jun 20, 2008 | 11:21 PM
  #34
12valve's Avatar
hmmmm... dang it!!!! I should have had a little more patience, and get a floor it. what do they cost? a stage 3?
coreydr303, i see you have the rail capped, should i do that? somehow i think its not letting it make anymore pressure. some say not to cap the rail, im confused
Old Jun 20, 2008 | 11:27 PM
  #35
Sloverado's Avatar
I have had mine capped for over 2 years. I cap mine because I have more pressure. I would cap it but I am like that. I think the Stage 3 is under 1400 but not sure. I run 2 modded pumps.
Old Jun 20, 2008 | 11:33 PM
  #36
Its caped cuz i dont want to blow a relief valve. That kinda pressure would blow one for sure with a single pump. you would need to talk to John on a price so DONT QUOTE this price $1400.00
Old Jun 20, 2008 | 11:42 PM
  #37
II sell safe pumps in my terms. I dont think they are so much hands on as John is with a pump. John spends alot of time creating things that alot others are lost at, mainly the FCA. Now im not putting II down one bit, look at some fact of the 2 pump makers and you'll git your answer.
The FCA is a very important tool when building pressure at WOT, plus you need FLOW. I would call both and ask for a flow chart. I know what the Floor It pump is doing as for flow, But not sure of the II. I think you would like the floor it pump, its direct bolt on and the stg3 from II needs some fab work. Its a Dmax pump.
Call John tell'um Corey,or Ryan (Sloverado) sent ya!!!! 785-842-8545
Old Jun 21, 2008 | 12:25 AM
  #38
bluechrome's Avatar
My Pump Is treating me and others very well. There is proof behind this sgt 3 pump. It works very well and keeps up with My sticks no problem with any program I throw at it. Plus John is a stand up guy with customers
Old Jun 22, 2008 | 03:46 AM
  #39
Billy Ram's Avatar
Originally Posted by 12valve
put on the II Stage 3 CP3
with Rail Pressure on the smarty set on #4, RP is in the 20,000 - 22,000 psi area at WOT on SW 9.
How does that sound?
i was hoping to see 26,000.
You should be seeing more rail pressure "22-24K" at wot. If you aren't loosing pressure comming from your pusher pump your relieve valve may be bad. These trucks like the pressure to be up there to make power.
adamsmarshall
13
Oct 7, 2008 06:54 PM
Jethro6213
19
Jul 11, 2008 11:59 AM
pullin hard
Mar 18, 2008 03:57 PM
BADBOWTIE
28
Jul 14, 2007 02:36 PM
megacabrule
33
May 10, 2007 01:07 PM
