bhaf part list
Old Aug 14, 2005 | 03:45 PM
rjm022's Avatar
bhaf part list
i went through all the old posts and saw some discrepencies of parts/part numbers needed to make ones own torque tube. if somebody could be so kind as to give me a complete part list with part numbers from their own order from cummins or airflow systems i would appreciate it. thanks
Old Aug 14, 2005 | 09:39 PM
nickleinonen's Avatar
this is what my bhaf and piping setup consists of... i got my stuff locally but you could get most if not all of these from airflow systems inc. my system is positioned a little diffreretly than most here that have a bhaf
1x bhaf element
2x 90° rubber elbows 4" ID on them
1x 90° short radius steel exhaust elbow 4" OD both ends
1x 4" exhaust pipe section ±3" long to join filter to elbow
5x 4" clamps [1 at filter, 2 at each end of rubber elbows]
Old Aug 15, 2005 | 04:12 AM
Dodgezilla's Avatar
rjm, lots of us used different parts to make similar end products. If you go to airflowonline.com and go to the intake section it's pretty self explanetory. 4" tubing is what you need. Two 4" rubber elbows, 1 length of 4" steel tubing, and 4 each 4" clamps. I had to do some rigging to make mine all work right. Look here for an explanation of what I did.. I'm "Got Diesel" over there....
http://www.dodgetalk.com/forums/showthread.php?t=55033
Old Aug 15, 2005 | 07:03 AM
rjm022's Avatar
thanks guys. i'll be picking up the stuff today!!
Old Aug 27, 2005 | 03:37 PM
txctd's Avatar
Is there a mod to be done to the stock air box to add a larger filter with more flow to go along with the torqe tube mod? I'd like to get a less restrictive intake to the turbo but $300 and up is way too much for what it is. I have little restriction now since I put a staight pipe on it, according to the stock guage mounted on the airbox. So whats the options?
Old Aug 27, 2005 | 06:31 PM
on the cheap, you could do a bhaf like this. bhaf filter and an elbow [i had a 90°, but a 70°-75° would be better] and it will fit stock piping after that...
Old Aug 27, 2005 | 07:46 PM
Dodgezilla's Avatar
Drill some holes in the bottom of the airbox and get an AFE Proguard 7 drop-in filter....
Old Aug 27, 2005 | 08:42 PM
caltom's Avatar
I did mine cheap similar to this.
http://dieselram.com/cgi-bin/ultimat...;f=29;t=003894
I used the same filter and 4" thin wall pvc pipe ( like for french drains and such) to mount the air sensor and connect the filter to the rubber hose.
Old Aug 27, 2005 | 10:02 PM
ftltmp's Avatar
I had the same set up , then I went with the cold air intake , you cah see a noticable diff in intake temps. The bhaf gets alot of eng heat and warm air through the radiator. just my .02
Old Aug 28, 2005 | 01:46 AM
fordsux8269's Avatar
The stock piping works just fine just cut that muffler thing out off it or get some straight pipe I dont really see why you need the big list of stuff to buy
Rickcher
Sep 2, 2009 05:08 PM
Ace
Oct 31, 2007 06:46 PM
tony
Apr 5, 2006 07:39 PM
Mixer Man
Sep 17, 2004 08:14 PM
NOTSTK
Apr 11, 2004 10:42 PM
