Best RPM to shift
Old Mar 5, 2007 | 10:26 PM
Gitpik's Avatar
Best RPM to shift
I have been up shifting at around 1600 to 1800 RPM with my truck. What speed does the membership shift at.?
Old Mar 5, 2007 | 10:53 PM
Farmer Davis's Avatar
Normal driving my rpms are close to yours, maybe a little lower. While towing, between 2000 and 2400. It all depends on load and grade of hill. Mostly, I shift based mostly on feel. The more you drive, the more you will get accustomed to shifting. Is your first manual tranny?
Old Mar 5, 2007 | 11:02 PM
Gitpik's Avatar
No have had lots of manuals, just wondering what the the membership was shifting at. Smoothest seems to be in that 1700 range but have not had a load on the truck yet.
Old Mar 5, 2007 | 11:44 PM
stock03's Avatar
Sometimes as low as about 1300 RPM. But that's when I'm barely touching the throttle. I can cruise at 30 MPH in 6th gear (speed limit on the military base out here) and it drives fine. But if I ever towed something heavy, I would be shifting at a lot higher range.
Old Mar 5, 2007 | 11:52 PM
templer's Avatar
I'm right around 1700 to 2000 under normal driving. Any lower unloaded and it sends a shock in the driveline. For me anyway.
Old Mar 6, 2007 | 12:02 AM
53 willys's Avatar
I like to shift at 2000-2400 that seems to be the smoothest spot for me
Old Mar 6, 2007 | 06:15 AM
MOJO1's Avatar
stock03 Sometimes as low as about 1300 RPM. But that's when I'm barely touching the throttle. I can cruise at 30 MPH in 6th gear (speed limit on the military base out here) and it drives fine. But if I ever towed something heavy, I would be shifting at a lot higher range.
I know what your saying when driving on base!Same here!Lower RPMs seem to help my fuel milge to.
Old Mar 6, 2007 | 07:19 AM
MikeyB's Avatar
Same here, I have smoother shifts between 2000-2400 rpms.
MikeyB
Old Mar 6, 2007 | 11:08 AM
cquestad's Avatar
1900-2000 rpms is the sweet spot for the engine....so I would think you would want to shift above that????
Old Mar 6, 2007 | 11:11 AM
35" 05''s Avatar
I like the 32-3300 rpm range with the SBC DD........so smooth
Old Mar 6, 2007 | 12:57 PM
templer's Avatar
Holly heck 35"05' with that rpm, eveyday is race day!
Old Mar 6, 2007 | 01:22 PM
rockcrawler304's Avatar
When the truck is warming up I shift about 1500-1700 and after it is warm and under normal conditions I shift at 1800-2100. Seems nice and smoothe and also helps the MPG a small amount.
Old Mar 6, 2007 | 03:14 PM
35" 05''s Avatar
let the race begin!!
jefjsak
Jan 15, 2015 03:44 PM
53 willys
31
Jan 31, 2008 02:24 PM
skeeter
Jan 18, 2006 03:17 PM
dieselnewbie
Apr 13, 2004 12:00 AM
fishin fever
Feb 22, 2004 08:32 PM
