Ball Joints !!!!again
Do not get Moog joints!
Do a search on this subject and decide for yourself. I took a set apart and posted pictures of them here. The lower ball is not a machined part and is not round. Consequently, they bind and gall which makes the truck steer very poorly. The upper joint is not a ball joint at all, but a pin in a bushing.
I put in a set of them and then had to go back and change them again. Be careful!
-Jeremy
They may have improved the design in the new trucks, I don't know. But at least you won't be getting a Powerjoke, where the joke's on you.
i did a google search and the xrf popped right up. Im not familier with the xrf company. As i did research i hear more positives about the dynatrac's so i think my investment will be going that way
Water ruins all joints that take grease. Water gets into the joint and then the joint will rust, rust then acts like sandpaper and eats the joint up. Use Lucas grease and no more problems. I've never had to replace a joint after using Lucas grease. And yes I go into water when its not frozen up North here all the time. Buy normal grease able joints at your local parts store and save your money. What it would cost you to buy these special joints you can buy several tubes of Lucas grease and grease all your neighbors trucks, including yours.
Unfortunately, "normal greaseable joints" that you refer too can turn out to be Moog joints from the auto parts store. These are a big mistake. We are all looking for durable, greaseable joints that are way better than stock and made better than Moog joints.
I have an idea. DTR store needs to carry balljoints. They'd make a million.
But first they'd have to cut them apart and let the folks decide after looking them over real well.
There are several different brands they could try out.
