Is this a bad rail pressure relief vavle cap?
Old Jun 22, 2009 | 07:48 PM
Matt S's Avatar
Is this a bad rail pressure relief valve cap?
I just installed my Garrett Stage 3 turbo. I was going to run it through it's paces and set the Smarty on lvl 9. I did a bonzi run and the truck stalled at 35 psi. It recovered but wouldn't push it past 35 psi. I now back fires after I put it back to lvl 3 (where I just towed across the entire country with no issues). I need some help with ideas on how to fix this. I don't have a gauge for the high pressure rail. I've got one on the low side.
Thanks,
Matt
Old Jun 23, 2009 | 01:02 AM
wardy70's Avatar
Take the bolt out of the banjo fitting on the pressure relief valve, if you have any fuel getting by at idle then the valve is bad. I had mine go bad and tapped the bolt and put a pipe plug in it.
Old Jun 23, 2009 | 05:58 AM
Matt S's Avatar
How close will I have to monitor my rail pressure if I run the Smarty on default rail pressure by blocking off the return?
sallyman1
Feb 14, 2009 12:30 AM
Snoxracer
Jul 15, 2008 11:09 PM
UnrulyNFS
NCDTR #18
Mar 21, 2008 04:39 PM
moparman13045
67
Oct 29, 2007 09:29 PM
