Auxilary Transmission filter
Old Jul 4, 2006 | 06:01 PM
Syndicate's Avatar
I was thinking of adding a spin on type filter on the line out of the trans to the cooler. There is short section of rubber hose that I can remove and hookup the filter head easily. What micron filter would be best? Is there one from Felltguard that would be best or is a fram PH8A like the one in the summit racing transmission filter kit good enough. I am goin to piece my own together localy so it all fits better for my specific application.
here is an example of what im talkin about.
http://store.summitracing.com/partde...5&autoview=sku
Old Jul 4, 2006 | 06:21 PM
TonyB's Avatar
Be careful with pressure drop (filter resistance) when using an aftermarket filter for the trans. I dont know about recently, but in the past some have tried it and starved the trans of oil (cooling and lubrication).
You may try calling a trans performance shop. I hear a lot of good on this site from georends and DTT.
HTH
Tony
Old Jul 4, 2006 | 09:11 PM
Syndicate's Avatar
I am aware pressure drop is BAD. Thats why I am asking what filter I should use.
Old Jul 5, 2006 | 10:00 AM
TonyB's Avatar
So...DTT is modifying or has modified your trans....Call 'em & see what they recommend.
Tony
Old Jul 5, 2006 | 01:48 PM
TAS05CTD610's Avatar
The stocker has a filter in it, and most don't recomend changing that out untill 50K or so miles. I would just drop the pan and replace that one. Lots to chance with a filter. Unless you plan on changing the filter more which you shouldn't due to more surface area than the stocker?? I would just change the stocker every 50 and call it good (you gota drain the fluid or flush it anyway)
Old Jul 5, 2006 | 10:05 PM
bob4x4's Avatar
WHO told you 50 k for a trans filter?????
Bob
silver bullitt
14
May 31, 2007 02:15 PM
dflesher
Dec 15, 2004 09:45 PM
Bad Ramer Jamer
Nov 21, 2004 07:05 PM
bigfish
24
Apr 1, 2004 01:50 PM
perk
17
Nov 2, 2003 08:06 PM
