Audio experts: Stereo/Speaker questions
Old Dec 27, 2012 | 12:42 PM
steelblitzkrieg's Avatar
DTR Detective
My right front speaker is crackling and I was looking to replace at minimum the front two, but hopefully all four.
1. Does anyone know the wattage rating on the factory standard single disc with the auxiliary jack?
2. Does the factory standard deck have enough power to push Polk db691 or db651s?
3. If needed what would the recommended minimum Amp output be for these speakers?
Polk dbs691 (6x9)
RMS 10-100 watts
Peak 300 watts
Polk db651s (6.5)
RMS 6-55 watts
Peak 165 watts
Old Dec 27, 2012 | 06:57 PM
1buck4me's Avatar
if you have the inffinity system there is a amp built in to it. the front speakers are called seperates. the tweeter/ high side is in the dash. the door 6x9 is only a midrange speaker. I had a set of kicker 3 ways in the door and would only get midrange sound from them. I think i tossed my stock ones otherwise i would let you have them. I will double check. I changed my whole system out and went aftermarket. It sounds a 100% better.
Old Dec 27, 2012 | 10:03 PM
DTR Detective
I have the stock four speaker system but I want to upgrade.
Old Dec 27, 2012 | 11:46 PM
1buck4me's Avatar
I put the pioneer 5 way 6x9 in front and the 4 way's in back. they sound great. They can handle the stock radio.
Old Dec 28, 2012 | 05:47 PM
ColinP's Avatar
If you have the basic 4 speaker stereo, adding 3.5" speakers in the empty spots on the dash will make a much bigger difference than replacing the rear 6.5" speakers. You can install the dash speakers in series with the front 6x9" speakers without stressing stock head unit. You will notice how terrible the power output of the stock stereo is when you install decent aftermarket speakers such as the Polk speakers you listed.
Old Dec 28, 2012 | 05:55 PM
ColinP's Avatar
Originally Posted by steelblitzkrieg
...what would the recommended minimum Amp output be for these speakers?
Polk dbs691 (6x9)
RMS 10-100 watts
Peak 300 watts
Polk db651s (6.5)
RMS 6-55 watts
Peak 165 watts
Those Polk speakers don't need much power but will have depth and sound clean with around 50w RMS power to each. The stock stereo will power them but it will still sound flat.
plug ugly
0
Sep 8, 2009 02:51 PM
Festus
21
Jan 28, 2009 10:04 PM
ImpulseHydro
Oct 8, 2007 01:23 AM
DodgeDemon
Jun 30, 2007 01:44 PM
BlackSunShyne
36
Dec 15, 2005 06:23 PM
