attitude monitor
Originally Posted by marc03
Has the issue with the trans slip function not working on the attitude after speedo recalibration been resolved?
No and it never will be acording to edge.
Guest
Posts: n/a
I had mine recalibrated a little while back and I still register the same amount of slip as before. I don't know if it's correct or not but it does change after I clear everything. I did notice that the speed on the Edge was way off after I had the speedo recalibrated so I set the tire size back to the stock #'s in the Attitude and it reads the same as my truck speedo. Maybe I stumbled across the "fix"? Someone else try it and see what happens.
I pretty sure mine works. I used this http://www.miata.net/garage/tirecalc.html to figure out the value for my attitude monitor and it has always seemed to give me a reading. (The previous owners changed the tires to something taller with out reflashing it.) Unloaded in stage 1 with my foot in it I could make it slip up to 5% and when pulling my trailer in stage 3 it would slip 5% all the time and on hills it would climb to 10% and then backdown. I just had a heavy duty TC from NADP put in today and already it is slippage is 1% or less and that just seems to pop up as it unlocks to shift.
Yeah, and for some reason mine will at random read up to only 10% then go to N. When I look at the records on the monitor, it reads 5470% or something crazy like that. one time it read 120%slip and I thought "ok if that was possible I wouldn't even be going anywhere" so I don't even worry about it. I have never messed with the tire sizing on the Monitor, so i "THINK" it has something to do with the Edge's overide of the factory tranny save feature when you select it to do so.
nitis
02-26-2007 07:38 PM
Hondo
03-03-2005 06:40 PM
powerstrokin03
13
10-18-2004 09:07 PM
Slice
08-17-2004 04:32 AM
