attitude monitor for EZ
Old Oct 4, 2004 | 06:59 PM
powerstrokin03's Avatar
I was at my local diesel performance store and they told me that the attitude monitor would work for the EZ once the attitude was released with the juice. is this true?
Old Oct 4, 2004 | 08:53 PM
osci's Avatar
nope only with the juice.
Old Oct 4, 2004 | 09:38 PM
well the reason im asking is because he said it would plug into the wire that the 3-way switch would plug into.
Old Oct 4, 2004 | 10:15 PM
quantrill88's Avatar
why did they go ahead and release the attitude then? It seems theyve been delaying the Juice box forever.....
I know its got gauges but thats about it w/o the Juice right?
Old Oct 4, 2004 | 10:34 PM
I think this guy may have been BSing me. who knows well see once it is released.
Old Oct 4, 2004 | 10:39 PM
Lsufan78's Avatar
seems to me that if it would work w/ just the ez they would've released the monitor already??
later, dustin
Old Oct 5, 2004 | 06:44 AM
Hoss's Avatar
Thats MR Hoss to you buddy!
I e-mailed Edge about this a while back and the response I got directly from Edge was that the Attitude would ONLY work with the Juice. It will not work with the EZ. Their recommendation, of course, was that if I wanted to use the Attitude then I should buy the Juice and stack it with the EZ. Attitude and EZ alone are not compatible though.
Here is the response I received from Jared Scholes at Edge:
Shane, No the Attitude will only work with the Juice, However the EZ will stack with the juice & Att. Some thing you might want to know is the boost can only go as high as 35 p.s.i without sustaining damage if you do stack them one day? We still do not have an ETA on the new box for the cummins. Have you registered on-line with the betta testing form for the new box? If not, please do and we can contact you threw that info. www.edgeproducts.com
Thanks,
Edge Products
Jared Scholes
1080 S. Depot Dr.
Ogden, Ut 84404
1-888-360-3343 x115
Old Oct 5, 2004 | 11:32 AM
Dodgezilla's Avatar
Edge told me the exact same thing they told Hoss! I've got guages now so I don't need the Attitude anymore...
One thing they wouldn't tell me was the exact hp/tq numbers for setting #5 or #6 on the EZ..Mine doesn't have #6 but I just wanted to know. I tried to get them to tell me the rail pressures at these settings but they just beat around the bush and wouldn't tell me.
Old Oct 5, 2004 | 11:54 AM
What do you mean settings 5 and 6 my switch is only 3-way how do you get 5 and 6
Old Oct 5, 2004 | 01:10 PM
Hoss's Avatar
5 and 6 are not advertised by Edge because they are likely to damage the engine because the fuel pressure is too high. Do some searches on the site though. By reconfiguring the little jumpers correctly on your EZ you should be able to get the 5 or 6 setting. If I remember correctly the 6 setting is good for 90 HP.
Old Oct 5, 2004 | 05:32 PM
Dodgezilla's Avatar
#6 doesn't do anything with my box but I do have #5. Yes, do a search as this was recently discussed with diagrams of the pin locations...
Old Oct 5, 2004 | 07:51 PM
osci's Avatar
theres no way it will work, because for the attitude to work it needs the trans slip wire, 3 fuel wires, map, egt, and one on the side of the block-which i have no idea what it does, and thats why the juice is a fueling, timming,boost not just fueling like the ez.
Old Oct 5, 2004 | 08:33 PM
mudslinger's Avatar
Powerstrokin is running the"600" box which has the 3 stage in cab switch instead of the jumpers, different system, similar box.
Old Oct 18, 2004 | 09:07 PM
swansong04's Avatar
i was at the BD dyno days on saturday and bd power has a ez attitude in the 04.5 r and d truck .. i ask them about it and they say had just got it the day before .. there was also two guys there from edge performance and they said it would be released in early november !! lets keep our fingers crossed !!
nitis
Feb 26, 2007 07:38 PM
agcntry
Jul 12, 2005 10:14 PM
Hondo
Mar 3, 2005 06:40 PM
Slice
Aug 17, 2004 04:32 AM
