ATS Exhaust Manifold/External wastegate Question
Old Aug 5, 2009 | 05:54 PM
ScienceOfSpeed's Avatar
i am going witha new turbo with an external wastegate, does anyone know a good shop that can fabricate and external wastegate pipe/mounting provision on my ATS manifold? i have seen several manifols done this way just never go info on who did the work. there are no fabricators in my town with the skill that can do this job. any info would be great.thanks
Old Aug 5, 2009 | 07:31 PM
JFlory's Avatar
Easiest way to do it is with a spacer. The spacer has an oval shaped hole in it that the blow off valve or wastegate is welded to. It just goes between the turbo and manifold and is about an 1 1/2" thick. Then you have to make some exhaust piping for it to dump into the down pipe.
This isn't exactly back yard mechanic stuff unless you have fabrication skills and a good welder.
Old Aug 5, 2009 | 07:37 PM
i saw that set up, Eds external wastegate is that way, i would rather have the wastegate on the manifold vs. a spacer,but thanks
Jambbii
May 6, 2006 12:09 AM
RowJ
Mar 1, 2005 04:50 PM
AK RAM
24
Jan 20, 2005 08:50 PM
KatDiesel
Mar 11, 2004 07:31 AM
