Ask Bud or Anyone about Bulldog PMT
Is the new version of the PMT on the website (1.0.1.0)? I think I'm at 1.0.0.8. And what updates are in the new version ? Also what temp should I set for the defueling. If I put the EGT after the turbo? Thanks for all your Help.
is the pmt stackable i have herd so much about it not having pressure i assume this means rail pressure to the injectors? do you guys use a fuel box with your pmt or is it a stand alone unit i have the pmt in the truck and have been browsing about hearing this over and over about pressure and bud says hes working on a new program to fix this so just wondering
I like it alot. I just use the regular settings Extremes the highest. And I have no trouble at all. It will put hard all the way to the limiter. I'm hoping that the newer version will be able to raise the rev limiter.
I'm not sure about the new regular download on the PMT, but if you get the new PMT Crazy Larry, you get the new 2.4.1 Triple Dog program that includes:
- adjustable rev limiter
- adjustable speed limiter
- adjustable tire size
We are also supposed to have pressure and boost fooling done through the Bullydog products sometime soon.
20073500dodge59 Will it be ok to run the Crazy Larry (if I'm careful) with a stock trany? And were is it the most critical? On take off or at top in? Thanks agian for all the help.
I thought the same but it is hard not to drive it to tis full power output! The lowend power is real strong as well on topend just be carefull and GOOD LUCK!
The stock 48re will only handle about an additional 100hp,depending on the driver and the program,of coarse each truck is slightly different too.
buy a tc at least that is the weekest link i am running the 5 star and have had no prob with my tranny knock on wood but i do plan on a vb and interal upgrades when i get home in two months but so far no prob
I just fried my tc after installing the crazy larry, i have a heavy foot but should have been smarter. It took dodge 35 days to figure out and replace my stock tranny. i am now waiting to get my truck back from dps in calgary, they are upgrading my tranny with a stage 3 ats package. if you go to crazy larry do not run it all the time if you have a heavyfoot like mine.
good luck:: chad
good luck:: chad
