Ask Bud or Anyone about Bulldog PMT
Old Oct 4, 2007 | 05:58 AM
  #31
MOJO1's Avatar
YES thats it!
Old Oct 4, 2007 | 06:34 AM
  #32
20073500dodge59's Avatar
Just making sure thanks
Old Oct 5, 2007 | 01:15 PM
  #33
On my boost gauge i can only get 22psi.out of it wide open. When I had the older verson 1.0.0.8 the boost would readed up to 34. Do i have a problem some were because that doesn't sound right only tops out at 22psi?
Old Oct 5, 2007 | 06:45 PM
  #34
Fisherguy's Avatar
Doesn't seem right, at least not the same as my 06.
I was getting 28-30 stock, I get about 40 now with the boost fooler.
Old Oct 10, 2007 | 11:28 AM
  #35
What kind of boost fooler works the best? And what does more boost do (Low end, High end)????
Old Oct 10, 2007 | 11:46 AM
  #36
MOJO1's Avatar
I only see 22lbs boost,Now thats on the PMT,Seems like it should be alot higher. I know i have the MP-8 that boost-fools but on a gauge no differance whats up?
Old Oct 10, 2007 | 11:53 AM
  #37
I called Buddy and he said he would try to get back to me today about the boost.
Old Oct 10, 2007 | 12:08 PM
  #38
claymeis's Avatar
I have the same problem
Old Oct 10, 2007 | 04:07 PM
  #39
Bud Kunz's Avatar
Okay guys sorry for not contacting anyone directly yet, but I have been working on this all day. Here is the deal. We changed our can bus boost request from the factory request to a standard pid request. It works fine down low, but as you guys found out the upper end of the boost curve is off. We will be switching back to the other method for requesting this on our next release. I am thinking I can send you three guys plus whoever else needs or wants it a beta version of the new stuff on Monday next week. The new software will also have the touch screen enabled as well. claymeis and ramble bee I have your email addresses. 20073500dodge59 or anyone else who wants this beta version on monday send me a PM with your email address.
Old Oct 10, 2007 | 04:16 PM
  #40
JD Dearden's Avatar
Do we have pressure yet or whatever
Old Oct 10, 2007 | 04:59 PM
  #41
MOJO1's Avatar
Thank you Buddy for the help. POWER TO THE BULLY-DOG
Old Oct 10, 2007 | 09:39 PM
  #42
claymeis's Avatar
X2...Thanks for all your patience and help, bud.
Old Oct 11, 2007 | 04:39 AM
  #43
Thanks for you help. I pm you my email. Anybody else have trouble with the high idle or is this just me?
Old Oct 11, 2007 | 10:49 AM
  #44
Bud Kunz's Avatar
I got your PM. I tested it today on our 2007 Mega Cab. I started with a new installation of the PMT. When I was done with the program the high idle did not work. I went to menu and then special functions and then idle up "auto only". It said it was enabled, but I knew it wasn't so I selected disabled and then enabled again. I then had to cycle the key off and when I cycled it back on and started the truck it worked. I hope that helps.
Old Oct 11, 2007 | 01:38 PM
  #45
That was it thanks. When will we get the rev limiter on the non crazy larry version?
