Anything wrong w/ using higher Smarty settings?
On a stock truck driving it around town like grandpa for the most part?
Scangauge II says better MPG using #5 on my truck. Stock trans. If I drive like a normal person / grandpa going speed limits is there a problem with this?
I would think the trans will struggle to keep up if I have my foot buried in the thing all the time...I would think that things will be ok using higher settings if I dont abuse the situation.
What do you all think?
Time will tell. Your a better person that me if you drive around town with a light foot with all that extra horsepower
^^&^ I agree. I ran level 7 on my truck when it had all the weak links, old clutch, old fuel pump, turbo, etc, and while it was fine, you can definitly cause trouble. The main thing is its hard to control all that power and keep it from slipping when you need WOT for something, like passing someone and seeing a car coming your way. So I would suggest you stay on the safest high level, sw5 and maybe just bump up to moderate tq management.
I drove to TS Perfomance's event this past weekend on level 9 4.4 beta(400+ miles one way)and got 19.2 mpg hand calculated.Decided to try level 3 for the ride home and only got 18.1. This was 95% interstate and driving like I had some sense about me.This is the first time I have ever had my truck off level 9 for any extended period of time.It went straight back to 9 when I got home!If your not jumping all over it I would say the higher levels will net better mpg's.
gpshemi
32
Jan 24, 2011 09:41 PM
johnr9q
13
Aug 8, 2009 01:59 PM
tristan21
13
Sep 12, 2007 10:48 PM
BDude555
Mar 18, 2004 07:27 PM
