Anyone install Daystar lift blocksl
Originally Posted by hilclmr
You will have to remove the sway bar end links also to let the axle fully drop.
Definately get a 4 wheel alignment to make sure your tracking is ok, and also get them to set it at max positive caster
Originally Posted by sherman
Does any one have pic's with the 1.5" spacers on a 2wd 4door 3rd gen dually?
MikeyB
Badram,
In your picture gallery, at the bottom of the picture you will see the photo properties listed. For the UBBCode cut and paste the line with [img]xxxx[/img] into your message box.
MikeyB
MikeyB
Badram
for a 1.5" lift, it sure looks good.
Pretty much what I'm expecting. Back a few months ago I believe cummins600 showed pic's of his 2" lift that looks exactly like your 1.5" lift. For some reason, the pic's of the two vehicles in this post with the same size lift do not look the same. Maybe just the angle the pic was taken or something. Anyone else notice this?
word of caution 1 1/2 doesnt level the truck but they do take out the big rake to look better , I and my bro inlaw installed these at the dealer he works at and the alignment went well but if you were to use the 2 1/2 spacers there is not enough adjustment to get it right allthough the 2 1/2's would give the level look , to me it would not be worth the bad handling esp. during towing. I am happy with this and the tires fit no problem , kinda was a chance on tire size since most go with 285's on 2 wd , I'm glad I did it...Now if I could fig out the right r.p.m. i'd be set.
P.s. thanks mikeyb
P.s. thanks mikeyb
Understand, I was'nt expecting the complete level look, just removing some of the rake and the 1.5" lift does just that. I do not want to replace the a-arms, ball joints or go with extended shocks associated with 2+ inch lifts because of the cost and possible poor handling issues. I've mentioned/written before that I like the Pre-Runner look, without all the added expense of 4wd and if DCX would offer it as an option I believe it would sell quite well.
Right now the stock tires still look new, even with 36k on the clock. I try to maintain my tires for as long as I can. I dont have alot of disposable income right now with a wife and daughter taking college classes.
But, I'd like to go up one tire size or stay stock and put on either a set of BFG's, yokahamas, bridgestones or nitto's. Not sure, but I am staying with 17" rims to avoid the whole speedo recal issue. It's still pretty hard to find OEM size fitment in a tire design that is AT/load range E.
RobV2500
Jan 18, 2009 05:44 AM
01350banshee
Feb 21, 2006 08:54 AM
Turbo Deeezle
Jul 12, 2004 11:54 AM
kry226
Jan 29, 2004 07:09 PM
