anyone bought a newer II tubro
Old May 21, 2010 | 12:53 PM
Topper's Avatar
All good advise CD!
Topper
Old May 21, 2010 | 02:16 PM
lu798welder's Avatar
Thanx for the advice fellers. I've got the braket hooked the exhaust manifold i just can't get my hand past the exhasut break to get the bolt back into the block. Is it better to get the bolt started in the block and then hook the one on the manifold stud or visa versa?
Old May 21, 2010 | 02:41 PM
BigJohnston's Avatar
BTW, don't use the stock studs from the turbo flange they are too long and you will get a large exhaust leak between the turbo and exhaust manifold. II should have included new ones with the turbo that are shorter. Good Luck, Tom J.
Old May 22, 2010 | 01:41 PM
Topper's Avatar
Hey lu798welder how about an update.
Topper
Old May 22, 2010 | 07:53 PM
Got it runnin. Topper I pm'd you a message on it for some help. Its running pretty good I just don't think its running like it should with all the upgrades i've done to it. I do have a good question for all you gear heads on here tho. I torqued all my rocker arms back to 27ft lbs and all the new head studs to 136ft lbs. I've ran the truck for 100 maybe 120 miles. Do I need to pull the valve cover and all that crap back off and re-tourque all that stuff?
Old May 22, 2010 | 09:04 PM
bob4x4's Avatar
Originally Posted by Topper
If you have some spray silicone use that. It will go on.
and right back off again
choppers555
Sep 23, 2009 12:16 PM
shift7171
Mar 4, 2008 05:26 PM
Garrett5462
Nov 5, 2007 05:28 AM
dieselfreak21
Aug 29, 2007 10:03 PM
tritont
25
Apr 11, 2007 10:50 AM
