Anyone Install a Valve Body 2005 and newer?
On the drivers side where the shift linkage is, there connects the electrical actuator. Can't figure out if you just unbolt the actuator, will it just slide right off the VB Rod? Then i am guessing the VB Rod just slides threw a rubber grommet on the removal?
Pics would be great if anyone has any?
Thats TTVC motor, unbolt from the trans and push it up and off the TV linkage. The shift and TV linkage is the same as all the previous units, integrated into the one column that goes thru a seal in the case.
I have dropped the VB and not replaced it with no leaks.
I have dropped the VB and not replaced it and it leaked.
A lot will depend on how clean the shaft is when you pull it down out of the seal. Clean everything off good and lube the part sticking above the case and a lot of times it will pull out without issue. What frequently happens is a build up of dirt gets left and it will rip the seal as it comes down, or, if the trans is fairly old the seal just gets wore and any disturbance is a reason to leak.
lu798welder
20
May 22, 2010 09:04 PM
12ValverDave
Nov 15, 2008 03:50 PM
Billwie
Dec 23, 2007 11:42 PM
tritont
25
Apr 11, 2007 10:50 AM
BCarmicle
Sep 14, 2005 07:27 PM
