Anyone with on board air compressor?
Old Nov 11, 2005 | 11:41 PM
DmaxEter's Avatar
I want to build myown air system using a York AC compressor. Has anyone else done this? If so, where did you mount the compressor? I will run one or two 5 gallon tanks. I would just like to hear some opinions and see some current setups if possible. Thank guys.
Old Nov 11, 2005 | 11:45 PM
mkubacak's Avatar
http://www.kilbyenterprises.com/products.htm
Old Nov 12, 2005 | 12:14 AM
DmaxEter's Avatar
YOWZER, over 200 bucks for just some brackets and such? I am glad I am building my own brackets. I just wonder if anyone else has built their own system? All the fittings, tanks, switches and such I will pickup from work. I guess my main question is what side to mount it on?
Old Nov 12, 2005 | 12:47 AM
oestreich84's Avatar
Do you want an engine driven compressor or a pto driven one? We have 2 trucks at work with on-board air systems. The old truck has an engine driven unit and it works ok, but it wont keep up with the 1" drive impacts. The newer truck has a pto driven compressor, and will keep up with the impact and pretty much anything you can run off of all 3 lines. Both trucks have a 28 gallon tank though.
Old Nov 12, 2005 | 06:29 PM
4x4not's Avatar
That $285 doesn't seem too bad considering what comes with the kit, and you KNOW it will be true. Brad (Kilby) is a really good guy to work with and he will help you out with anything you need. I have one of his York brackets in my Jeep, but I'm thinking of moving my OBA setup to the truck and just using CO2 in the Jeep since I trailer it anyway.
Old Nov 13, 2005 | 01:38 AM
DmaxEter's Avatar
The more I look under the hood and see that there isnt a lot pf room, the more I think that aint a bad price for that setup. I have the york setup on my rock crawler, but that was easy because the engine had a yor bracket and pulleys already on it. I got two new york compressors sitting in the garage and only need one. How much is one worth to someone that needs one?
rhino 660
Oct 21, 2006 05:33 PM
BearKiller
Aug 29, 2006 05:20 PM
JKM
Mar 8, 2006 03:23 AM
wheelin66
Dec 25, 2005 07:30 PM
durasmack
Oct 4, 2005 09:52 PM
