another twins question about oil lines?
Old Nov 9, 2008 | 08:56 PM
kyle_truck_pull's Avatar
Question another twins question about oil lines?
how do you hook up the oil lines for twins? how does that work if you want to do your own set of twins? any pics or ideas?
Old Nov 9, 2008 | 09:17 PM
soulezoo's Avatar
DTR 1st Sergeant
On the top of your oil filter housing are two brass plugs. Remove one of the plugs and use that to hook an oil line into and run to the turbo. It will use different fittings than your stock oil outlet though.
Old Nov 9, 2008 | 11:04 PM
chrleb1's Avatar
On mine, I plugged the stock outlet and used both of the top outlets of the filter housing. Made my own lines with 4AN SS line and fittings.
Old Nov 10, 2008 | 06:54 PM
where did the oil drain lines off the bottom of the turbos go?
Old Nov 10, 2008 | 07:14 PM
bluechrome's Avatar
In the block
Old Nov 11, 2008 | 06:17 AM
i thougth there was only one plug in the side of the block.
Old Nov 11, 2008 | 12:51 PM
soulezoo's Avatar
DTR 1st Sergeant
You have to punch out the freeze plug just aft of the oil filter housing to install the other drain. Typically, the lower (primary) turbo uses the stock oil return drain hole and the upper turbo will utilize the forward plug. Some twin designs will drain both turbos into one drain line, but that is also typically not the best method.
dodgediesel
ABDTR #5
Oct 18, 2011 09:22 PM
dodgediesel
ABDTR #5
496
Oct 16, 2011 04:33 PM
dodgediesel
17
Apr 5, 2011 11:21 AM
Stock 02
28
Sep 24, 2006 11:09 AM
BCarmicle
Feb 8, 2006 07:11 PM
