amsoil dual bypass?
Old May 18, 2008 | 09:01 PM
WUnderwood's Avatar
amsoil dual bypass?
Anyone know what size the steel braided oil line is for the Amsoil dual bypass?
Thanks in advance
Old May 18, 2008 | 09:09 PM
renopker's Avatar
its #8 thats 1/2
Old May 18, 2008 | 09:53 PM
WUnderwood's Avatar
ID or OD?
thanks a lot
Old May 18, 2008 | 09:58 PM
AH64ID's Avatar
I used 1/4" ID for my single bypass, and since there a restriction orifice, very small but dont recall the size, .0x, I don't think you would need more than 1/4" for two bypass filters.
Old May 19, 2008 | 09:13 PM
carl48's Avatar
it is 0.078" 1/4 hydraulic line is best
Old May 19, 2008 | 09:25 PM
carl48's Avatar
make sure you have a dual bypass and not a dual filter unit that replaces the primary filter your unit needs to have both filters be the 110's, the dual was made for the 8.3 and i am not familiar enough with it to know if the orifice is larger i would call chuck and ask or go on line and check or add a orifice to the fitting that you put on the permanent filter housing use any drill bit between 0.060 to 0.075 and you will be ok if it is a dual filter just sell it do not use it
Gumby
Aug 11, 2009 12:45 PM
rjm022
Feb 16, 2005 08:07 PM
Lightman
May 3, 2004 08:53 PM
dodgediesel4x4
Dec 17, 2003 02:05 PM
RKCRWLR
Jun 27, 2003 09:01 AM
