AirDog 150... where/how did you mount your FP gauge?
Old Aug 31, 2008 | 08:08 AM
madhat's Avatar
Administrator/Jarhead
Mornin, DTR... Just got a new AD150... Where did you mount your guage tap? Did you use a T fitting to do it?
Plus, I have the AD for an 05, mine's an 04.5... anything I should know?
TIA...
Mad
Old Aug 31, 2008 | 08:15 AM
mishkaya's Avatar
TIA...
Mad
Yes I just used a tee fitting similar to this:
As for the '05 thing, I can't help you.
mishkaya
Old Aug 31, 2008 | 08:51 AM
madhat's Avatar
Thanks... did you get it online, or at a store in town?
Old Aug 31, 2008 | 08:54 AM
mishkaya's Avatar
I got it from Summit, but if you have a local racing shop they should carry that type of thing.
mishkaya
Old Aug 31, 2008 | 08:59 AM
53 willys's Avatar
do you have the stock intank pump or canister mounted pump?
Old Aug 31, 2008 | 09:07 AM
madhat's Avatar
Canister... but I took that off a long time ago.
Old Aug 31, 2008 | 09:48 AM
53 willys's Avatar
hmmm if you still have the canister mounted wiring harness you should have ordered a early kit...then it would be plug and play.
with the 05 harness you will have to find the FP trigger wire and tap it with the red trigger wire on the AD harness.
Old Aug 31, 2008 | 10:45 AM
madhat's Avatar
Roger dodger... I figured that... guess I gotta wait till Tuesday so I can send it back...
Old Aug 31, 2008 | 10:59 AM
rip 112's Avatar
I just went to NAPA and pieced together fittings and sealed them. No problems at all, even with it being close to the CP3.
Old Aug 31, 2008 | 11:04 AM
han solo's Avatar
Vulcan sells a fitting that will work for you. With the air dog you put the supply pump line right to the CP3, with the supplied fitting that screws in, then you use a barb fitting into the blue fuel line. Instead of that barbed fitting that comes with it, vulcan sells a 90' fitting with the same barb, but the fitting is tapped for 1/8th pipe. Take the fuel pressure reading at the inlet of the CP3. Its under JIC fittings on there web site, called pushon 90 degree 08 jic fitting tapped, cost 7.99. Its alot for a fitting, but makes the install nice and clean looking. At least you can see the fitting and find it local.
Old Aug 31, 2008 | 11:17 AM
madhat's Avatar
Rip, thanks for the pics... That looks like an isspro isolator and tubing... diesel manor? I like that SS braided line too... did you get that made?
Han, I see what you're saying. I was thinking about doing something like rip did, but closer to where the stock FF canister is now. I am using brass tubing for my FP guage line, and the shorter the better...
Old Aug 31, 2008 | 11:32 AM
rip 112's Avatar
No, the ss line came from Diesel manor also, along with the Isspro stuff. Its an option, and i accidentally got the ss kit with the banjo fitting, which i couldn't use.
Here's a link to it.
http://www.dieselmanor.com/dm_products/DM-FPH.asp
90 power ram
Apr 4, 2013 02:22 PM
CrashCade
Dec 3, 2008 07:58 AM
dodgediesel
26
Nov 2, 2008 12:20 PM
WACTD
31
Apr 14, 2007 10:55 AM
PapaSmurf
Jul 18, 2004 05:21 PM
