Where did you mount your CB radio?
Hello
I am getting ready to mount a CB in my wifes truck and would like to see how you mounted yours. Please post a picture. We have the auto trans and flip down cup holders in her truck, don't really have alot of room on the center hump.
Thank you
See Ya
Chris
Thank you
See Ya
Chris
Buy one of the COBRA one handers and then mount the box under the cup holder behind the plastic panel. Then buy the extition cable and mount the end in the panel to the right of the radio. All I did was drill the hole and install it there. Now all you see is the plug coming out of the console, I keep the CB in the storage compartment until needed.
I don't have a picture. I mounted mine by drilling two holes for the bracket in the sun glass/garge door opener console. The useless console pops out & there is a metel bracket that the console mounts to from the roof. I drilled into it & used sheet metal screws to hold the cb bracket. Ran the wires & dual coax down the apillers for dual antenas. If you have a big cb you could tap the holes instead of useing screws. Mine is a small Uniden. I like having it up were I can see it's just like it is in my big rig. Oh by the way I had to discard the rear view mirror, never use the thing anyway. Don't have one in my big rig either.
I don't have any pics, but I have a small Uniden also. I removed the plastic panel below the steering wheel and mounted the CB on the right side of it as high as I could. When I replaced the panel, the CB sits just to the left of my center consol. I can see it pretty well and running the wires was easy. I bump my knee on it every once in a while, but its not too bad.
Mine is in the center seat storage...the bottom one.
I have an external spkr mounted on the right side of the panel under the center of the dash and I drilled a hole thru the floor of the storage and ran the mike cable/antenna cable and power lead thru there. If I need to switch channels or adjust the radio I just open up the bottom seat storage.
This will have to change if I go to a center sub.
90 power ram
Apr 4, 2013 02:22 PM
WEATHERBY460
14
May 27, 2009 09:04 AM
madhat
Aug 31, 2008 11:32 AM
WACTD
31
Apr 14, 2007 10:55 AM
ckt_santiago
Jan 23, 2007 12:12 AM
