AirDog 150 & tank vent mod install on a Megacab
#61
#62
#63
if you were to get rid of the stock filter canister and heater wouldnt it trigger an engine light because the ecm wont see the heater is working? much like the intake heater grid? what do the airdog instructions say to do, keep the canister and get rid of the filter or bypass the canister/heater all together?
i too will be going w/ the airdog150 sometime soon before upgrading my turbo. thanks for the writeup, it really is great!
...a resistor should take care of the CEL but dont ask me the value cause I dont know it yet
#64
if you have steady FP supplied to the CP3...and your drainning the rail then YES you DO need a upgraded CP3
#65
Sorry, what I an stating is if you do not have adequate fuel supply to the cp3 then tossing an upgraded cp3 on will do absolutely nothing, since it won't have the fuel supply to feed the rail. I always start with the basics, make sure fuel supply, and delivery to the injection device is adequate, then go on from there.
Tim
Tim
#66
Originally hvytrkmech was qouting someone else saying he needed an upgraded cp3. But, first he needs to get the fuel to the cp3. Megaboom does not have an upgraded fuel system. If you go back and read starting at Megabooms post it'll make sense.
#67
before the AD I could suck my FP to zero and the rail would stay full....this is on a WOT run...by the time my handshaker hit redline the FP read zero and the rail was still 24k+.....yes if I stayed on it it would probably drain the rail but I never could take it to any higher speeds to see the rail drain...
you are correct tho..if you dont have a aftermarket lift pump you should defiantly get one before upgrading your CP3..
#68
Tim
Tim
#70
Gents,
Anyone see any issue with running an airdog 150, the Jeep Replacement In Tank Pickup and the http://www.glacierdieselpower.com/pr...x?pf_id=0306FE.....
Will the Jeep Part be too small of a pickup for the AD150?
Sorry if this has been answered in one of the 3000 threads, i didnt notice it if it has...thanks in advance
#71
Gents,
#72
Charlie@ Pureflow told me the stock pick up is too small for the AD150 be it a liberty canister or the dodge canister the AD100 will be fine...I think I am going to try lib can...but I am going to plumb a 1/2" pick up into it.....and maybe the airdog return line...the only worry with the r-line is it has all the bubbles and air in it so that may make the Airdog run louder since it would be sucking the return line fuel up???
I will keep yall posted
#73
I believe the liberty pick up assembly has a 3/8" pick up tube.
You won't be able to flow the 150gph at 15-18psi of fuel pump pressure using the above p/u. That is why you get a 1/2" pick up draw straw on the 150 and above. The A/D 100 with the factory quick connects is said to support up to 550hp. As far as eliminating the stock ff housing, its up to you, no real performance benefit either way, removing it is purely for asthetics.
Tim
Tim
#74
You bring up an excellent point, please do keep us up to speed.
Thanks,
Tim
#75
so you wouldnt have to cut your tank for the airdog 100 because you can keep the stock tube? how many gph improvment is the ad100 over stock, and do you guys think it would actually support 550hp?
i wanted to try and get around the 600 hp range to run the et's i would like but it sounds like the ad100 would be a much easier install if you dont have to cut the tank. i wonder if i could get away w/ the ad100?
