AFE Question
Old Jun 10, 2007 | 01:27 PM
Graphite 6's Avatar
AFE Question
Howdy, My understanding is the differences between the AFE StageI and II is
Stage II, Torque tube is 6" at the box w/ a reduction to ? by the turbo.
Base of filter is also 6"
Heat shield comes w/a top.
What else?
Stage I, Stock tube, unless you by a TT
Base filter 4"
Obviously no shield top
Thanks.
Old Jun 10, 2007 | 02:35 PM
tbarbee1's Avatar
I think you are correct I have the AFE Stage II and it is a great intake/filter combo. If I were to do it again I would build a ****** whistler they are basiclly the same setup for about 1/4 of the price you can do a search for ****** whistler to see pics and the write up on how its built. The whistler is also louder than my AFE.
Old Jun 10, 2007 | 05:06 PM
jwb600's Avatar
the afe stage 2 I ran was very close to my oil filter which I was not a fan of. the afe stage 1 I ran with a tq tube and it fit alot better. you can build something much cheaper that does the same thing like he said above. some 4" pipe and a big filter you will be set.
Old Jun 11, 2007 | 12:41 AM
PourinDiesel's Avatar
What else?
Base filter 4"
Thanks.
Sounds like you have it down right.
Old Jun 11, 2007 | 07:47 AM
RamWheelsBy4's Avatar
Yep, like stated above, you have it correct. I have had both with all of the different filter options. Probably over priced, but they are good products.
Stage I with TT
Stage II without top cover on.
Old Jun 11, 2007 | 08:40 AM
IrishND's Avatar
Those of you who have the Stage II, do you keep the top cover on it? Or should I take it off.
Bob
Old Jun 11, 2007 | 08:45 AM
jrussell's Avatar
Bob
I would keep it on...can't hurt.
My recent data logging at the track showed intake temps reaching 118* by the end of the run.
Old Jun 11, 2007 | 08:55 AM
Graphite 6's Avatar
RamWheelsBy4, Those are excellent pics. Thanks.
Old Jun 11, 2007 | 09:20 AM
Bob
I left mine off. I can't really see where it will make any real difference except while idleing.
Put it on if it makes you feel better, it certainly won't hurt anything.
sinawalli
Mar 5, 2011 08:43 PM
surfram
Jul 17, 2006 02:06 PM
diesel_work
Oct 8, 2005 12:25 PM
sawboywv1
Jul 15, 2004 10:31 AM
chrismez
Aug 21, 2003 09:39 PM
