AFE filter problem
Old Feb 27, 2007 | 08:59 AM
BlackSunShyne's Avatar
AEM filter problem
I have installed the AEM bruteforce dry filter system. I love the sound, air flow, and air temp. But am having a problem. The filter falls off of the metal tubing. Has anyone else had this problem? And if so what did you do to fix it? I can tell from the turbo noise when it falls off, and stop and put it back on. And also i check it daily now, but don't want to have to check it all the time. Can anyone give me some advise here.....?
On the edit, I just noticed I typed AFE instead of AEM on the Title of this thread. I am so smurt sumetymez....
Old Feb 27, 2007 | 09:53 AM
RamWheelsBy4's Avatar
Well not having seen one in person, this is just my get-r-done suggestion. Get some heat resistant tape and wrap the pipe to increase the diameter enough so the filter can be tightened securely.
I would say duct tape, but heat will eventually make it dry and crack .
Old Feb 27, 2007 | 08:07 PM
skynyrd's Avatar
if you take the end of the tube and place 4 self drilling mini screws in the intake pipe slide the filter over them and tighten the band down behind the screws. you could gring the extra screw off one in the pipe, but not to much they are silver screws line 3/8 of inch long with self drilling tips. they are used for metal stud work in construction alot of times. worth a shot
Old Feb 27, 2007 | 09:03 PM
bekim's Avatar
Just tighten the b-jesus out of the clamp. Mine has yet to even move a millimeter. I know what ya mean though, those tubes are slicker than snot new.
Cheers
Mike
Just got the Workhorse replacement filter for the AEM intake today. It's HUGE compared to the stock AEM Dryflow unit in my picture! Won't even fit in the space wher the filter is now.
Attached Thumbnails AFE filter problem-bruteforce2.jpg   AFE filter problem-aem-workhorse.jpg   AFE filter problem-aem-workhorse2.jpg
Old Feb 27, 2007 | 09:08 PM
skynyrd's Avatar
you could try taking a piece of sandpaper adn roughing up just where the filter clamps on!! just my $.02
Old Feb 28, 2007 | 07:53 AM
That might be the best thing to start out with. That metal is just slick as snot on a door ****!!
Old Mar 30, 2007 | 07:50 PM
vj_M's Avatar
I took Piler's and bent little tabs up ward all around it
Old Mar 31, 2007 | 10:39 AM
ramtd02's Avatar
dont tighten the b-jesus out of it....the tube will bend, and the rubber on the filter will tear!!! Go with the four drill holes and small set screws!!
sinawalli
Mar 5, 2011 08:43 PM
bc3
Nov 13, 2010 08:35 AM
surfram
Jul 17, 2006 02:06 PM
diesel_work
Oct 8, 2005 12:25 PM
sawboywv1
Jul 15, 2004 10:31 AM
