Adjustable Boost Elbow??
Old Nov 14, 2006 | 07:00 AM
sawboywv1's Avatar
Any ill effects of adding this goody..Too much boost???
Old Nov 14, 2006 | 07:22 AM
MikeyB's Avatar
It's safe to use if the pressure is kept below 35psi. The '03-04 turbos doesn't live very long above that.
Mine is set to around 32-33psi with the SMARTY on level 3.
MikeyB
Old Nov 14, 2006 | 07:41 AM
sawboywv1's Avatar
I don't have gauges yet!! Should I leave it in the setting that it arrived in from our friend?
Old Nov 14, 2006 | 07:50 AM
MikeyB's Avatar
Personally I would get the gauges first so you will know what the baseline is.
Does the Diablo Predator have boost fooling?
MikeyB
Old Nov 14, 2006 | 08:24 AM
sawboywv1's Avatar
MikeyB
1. I don't dog the truck at all
2. No gauges yet
3. Our maker of the elbow says run where it is set??
4. I assume the predator has boost fooling as I set no codes
5. Maybe back the set screw alittle till I get the gauges??
Thanks
Hdog
Oct 27, 2014 10:52 AM
dodgediesel
14
Dec 14, 2006 09:54 AM
CSAGrey1
Mar 7, 2006 10:54 AM
turbo dreams
Jun 1, 2005 02:49 PM
