Adding a Dual Feed Line ON a Stock CP3???
Old Feb 25, 2007 | 10:15 PM
OldSmokey's Avatar
I remember reading that a shop must be certified to deal with those types of pressures. I cant remember who it was but he was going to try and do just that ******.
Old Feb 26, 2007 | 07:24 AM
tcr's Avatar
tcr
I have the II dual line feed kit, and it is worth every penny(300.00), although I didn't pay near that much. I was draining the rail BAD before the install, it has actually increased top end pull dramatically. Install is kinda tricky because you have to be a 300lb gorilla to get the fittings tight enough to not leak. I'm only a 252lb part gorilla when I drink enough. It is not only a HP hose w/ some HP fittings. There are two adapters that might be hard to find. I'll have info soon on a shop who's trying to have these built and certified . This is the hard part, certifying to 60000psi. I'll let you guys know if he pulls it off, they will be much cheaper than 300 bones.
Old Feb 26, 2007 | 09:13 AM
NGM Diesel 1's Avatar
i agree guys it does work and it is worth the money.
having someone in the country capable and willing to produce a line like that-that's flexable is NOT going to happen. these lines are outsorced over sea's directly from bosch.
Ad removed site violation
Old Feb 26, 2007 | 09:24 AM
tcr's Avatar
tcr
having someone in the country capable and willing to produce a line like that-that's flexable is NOT going to happen. these lines are outsorced over sea's directly from bosch,
That will be cool just as long as it's not adding another fitting in line that can leak.
Old Feb 26, 2007 | 09:53 AM
cquestad's Avatar
I bet it helps some alone on the volum eincrease of fuel between the CP# and your injectors. The quantity of "pressurized fuel" is greater....like twest's bored rail. Don M has stated and I agree that hydraulic theory should prove the location(s) of filling the rail are wrong.
Old Feb 26, 2007 | 10:01 AM
53 willys's Avatar
having someone in the country capable and willing to produce a line like that-that's flexable is NOT going to happen. these lines are outsorced over sea's directly from bosch, we will soon have the adapter that will allow for a relief valve and a duel feed line at the same time, that will be way cool in my book
supposedly the line is just Parker polyflex line..if you find a dealer who deals with the line I am sure they could build you on in the states.....
keeping the Relief valve in line would be sweet too.
Old Feb 26, 2007 | 10:25 AM
i dont know, but last i checked(6 months ago) no one else was making one?
Old Feb 26, 2007 | 10:43 AM
53 willys's Avatar
I found 3 dealers right here in Utah....
I just talked to one of them they are calling me back with a price
anybody know what size the fitting are so I don't have to take my truck apart to see?????
Old Feb 26, 2007 | 10:48 AM
tcr's Avatar
tcr
It's not just finding a parker dealer, it's getting the additional fittings, along w/ getting the built line certified/tested for the pressures we're running w/ a combustible fuel. As I stated before, there is a large volume dealer working on this, and if he can't get it done, I suspect NGM Diesel 1 will be correct.
Old Feb 26, 2007 | 02:09 PM
53 willys's Avatar
I will see what happens. No harm in trying
II is 20mins from my house...it would not surprise me one bit if II was having there hoses built right here in town at one of the dealers....
I am just wondering...if the hose and fitting are already rated for 60000PSI and made buy the hose dealer why would it need to be certified??
I don't know why I care I don't even need a dual feed line
the only way my rail is going to drain is if I spring a leak!
Anybody know what the fitting sizes are yet???
Old Feb 26, 2007 | 02:14 PM
haha, thats funny
Old Feb 26, 2007 | 02:19 PM
53 willys's Avatar
haha, thats funny
what do you mean?
Old Feb 26, 2007 | 02:43 PM
what do you mean?
"the only way my rail is going to drain is if I spring a leak! "
that was funny!
Old Feb 26, 2007 | 05:45 PM
abc4yew's Avatar
I have one sitting in the closet.....maybe I'll pull it out and try it....All I know is that when I was running the CP3.4 ....the truck made alot more power with the rail cap on but it didn't run as smoothly.....run on once the go pedal was released. 10 to 25% more power from a hose is quite an accomplishment....It must be a volume thing but that hose is about 3 mm internal diameter. Must be a combination of the volume in the pump and the hose that makes it work better plus the dual supply means cylinders 4 through 6 have a closer supply of fuel. ks
Old Feb 26, 2007 | 07:18 PM
53 willys's Avatar
you wanna take some photos of it and post them up???
does it say what size it is on the side of the hose?
also what is a CP3.4??
Thanks
