5" Turbo-Back Duals from Magnaflow?!!!?
Old Nov 7, 2006 | 01:02 AM
D.Wiggs's Avatar
Question 5" Turbo-Back Duals from Magnaflow?!!!?
Here is the link: http://www.xtremediesel.com/index.as...l=&strCompare=
Am I mistaken or does it look like there is now a 5" turbo-back dual exhaust system? How much of a difference do duals make versus single when you are talking about the same diameter. I have the 5" turbo back single exhaust and, if I don't do stacks, I might do this, or am I mis-reading something?
Old Nov 7, 2006 | 01:12 AM
53 willys's Avatar
If it's single all the way to the muffler then it's not going to be better or worse then stacks.
But the stacks look waaaaaaaaaaaay cooler IMO, do the stacks!!!
Old Nov 7, 2006 | 01:22 AM
D.Wiggs's Avatar
That part I knew. What I meant was, would it be any better than my SINGLE 5" Turbo Back?
I agree stacks are cool!
Old Nov 7, 2006 | 09:14 AM
53 willys's Avatar
No, I don't think it will be any better then what you have now.
Old Nov 7, 2006 | 09:36 AM
Argo's Avatar
mbrp has dual 5" too I think. maybe it is the magnaflow I am thinking of.
Old Nov 7, 2006 | 10:18 AM
jmccart's Avatar
I would like twins in the rear to more evenly disperse the smoke. Hu hu hu.
Old Nov 7, 2006 | 12:57 PM
D.Wiggs's Avatar
Good thinking!
Old Nov 7, 2006 | 01:38 PM
acook's Avatar
Same here! Do duals sounds any different then singles?
Old Nov 7, 2006 | 01:40 PM
WUnderwood's Avatar
I have duals, and I think they are great, smoke/sound out of both sides, and I think it puts a good balance from the rear of the truck
hope this helps
Old Nov 7, 2006 | 01:42 PM
Luken's Avatar
There is NO benefit in duals over a single... Except looks if your into that look. Personally I think duals on a diesel is
Just my opinion tho
Old Nov 7, 2006 | 01:45 PM
acook's Avatar
Just my opinion tho
Looks like you have dual stacks, instead of sticking up their just sticking out.
Old Nov 7, 2006 | 01:47 PM
35" 05''s Avatar
smoke shoots farther out of one pipe
Old Nov 7, 2006 | 01:51 PM
D.Wiggs's Avatar
If that's the case, wouldn't that mean that there was more pressure with one than two and therefore two (since they create less pressure) would allow exhaust to escape faster and therefore reduce EGTs.
Old Nov 7, 2006 | 01:59 PM
Luken's Avatar
No when you put a y-pipe in to split, it slows the exhaust down a ton. It creates backpressure. That's why it doesn't come out as quick as a single.
Plus you have 12 inches of pipe instead of 6. The same amount of smoke is coming out...
Old Nov 7, 2006 | 02:01 PM
Luken's Avatar
I liked the look of 2 stacks... I thought I would be somewhat different and bring them in on each side of the slider. Now everyone and their brother has the SAME EXACT stack setup on their trucks around here. Im about ready to yank them off for the winter at least.
