4 power adders + 195hp Cummins = 604.8hp
Old Mar 28, 2006 | 05:02 PM
  #31
502502's Avatar
Originally Posted by Green04HO
But your dyno numbers are with the injectors and the CP3 right?
I have dyno runs with CP3 only, and then with Cp3 and injectors.
Heck I have dynoed 33 times on John's dyno. I think I have more miles on the rollers then on the pavement
Old Mar 28, 2006 | 05:10 PM
  #32
Green04HO's Avatar
How about just the CP3 with your new fuel pump? Looking to see if the CP3 added anything by itself when you added your new FASS.(minus the new injectors)
Old Mar 28, 2006 | 07:22 PM
  #33
502502's Avatar
I did not try that combo. But I dont think I picked up much top end.
I did pickup 120hp in the mid-range, but no peak HP that I can prove.
Old May 27, 2006 | 12:05 PM
  #34
Camotanker's Avatar
Show how she still running? any news / discoveries?
Old May 28, 2006 | 02:19 PM
  #35
502502's Avatar
Shes running really good. I leave it on the 600hp setting most of the time, Just turn down the torq setting so I dont smoke alot.
EGTS are still good. Although with my turbo, the low end EGTS are high.. but at 1200, they stop cold _ unless I am really getting stupid
THose injectors were by far the BEST MOD I HAVE DID - period.
Old May 28, 2006 | 03:24 PM
  #36
Billy Ram's Avatar
I got about the same results as Tomygun with stock injectors and stage I cp3. Running the pressure up to 40psi on the pusher pump didn't make any differance over 25psi on the stock injectors. The 95gph Airdog did very well only dropping to 40psi set at 42psi. Big differance in the curve. Smooth with out the dips and bumps 3rd gen have. The only thing for me to do now is injectors when they are ready for the 04.5.
Ken Collins
Jul 19, 2009 06:42 AM
ram 2500
Jul 24, 2008 03:37 PM
ram 2500
Jul 13, 2008 08:53 PM
4ord422
Jan 22, 2007 06:10 PM
mhuppertz
Aug 24, 2006 10:54 PM
