Power Adders
Old Jan 22, 2007 | 01:44 PM
4ord422's Avatar
Power Adders
Okay, I've got the Edge with Attitude and I love it. Just like other people, I'd like more power. I've read that the Edge/Attitude does everything but pressure and the Edge EZ does pressure. First off, is that correct and if so, would stacking the Edge EZ with the Edge/Attitude get me closer to what I'm after? Oh, and if you're curious what I'm after-I'm not sure, other than more power.
Thanks
Old Jan 22, 2007 | 01:51 PM
goodeyesniper75's Avatar
yes that is true it will give you mare power.
Old Jan 22, 2007 | 02:04 PM
BlackSunShyne's Avatar
I am kind of interested in doing the same kind of upgrade. I like the Edge J/A, but more is always better If you do the Edge EZ, which of course adds pressure, would you be ahead to go ahead and do some new injectors as well, say F1 or even F2? Or would it be a better route to do the Hot J/A, Walbro, Edge EZ, then injectors? Of course by that time you probably need to look at a bigger turbo too.
OK, I need to go water the money tree in the backyard....
With the Edge J/A and the Edge EZ, you might want to look into some work on the auto tranny as well tho..?
Old Jan 22, 2007 | 03:52 PM
3500lly's Avatar
Thanks
I would look at doing your intake at the same time you put the EZ on, then you might become addicted and the next step will be the tranny
Old Jan 22, 2007 | 05:12 PM
BigDave12768's Avatar
Yeah I would put a cold air intake on next. And if you want to add pressure to that box send it back to Edge and have the hot upgrade done to it. That adds presure. But ify ou want more HP you have to do the other things like the cold air box and a higher flowing muffler or straight pipe.
Old Jan 22, 2007 | 06:10 PM
973604x4's Avatar
I don't think the Hot Juice adds pressure on 04.5+ trucks. It does on 03-04 trucks.
I had a Hot Juice/ MP8 stack...and it flat hauled butt...or i thought it did. Now with a bigger turbo and more fuel, i can drift
I also have tried a Juice/EZ stack. With tranny, fuel system, and intake i turned a 13.96 with the Juice/EZ stack.
Ken Collins
Jul 19, 2009 06:42 AM
ram 2500
Jul 24, 2008 03:37 PM
ram 2500
Jul 13, 2008 08:53 PM
mhuppertz
Aug 24, 2006 10:54 PM
502502
35
May 28, 2006 03:24 PM
