4 inch lights for Road Armor Bumper
the piaa 510's fit perfectly in the road armor bumpers. there is just enough room to adjust the beams up/down and to allow bulb replacement. imo spend a couple of extra $$ and get the piaa's that fit perfectly, work good, and look great.
Pilot PL-360C lights would probably work 4" in diameter or for a little more room for adjusting lights Pilot PL-330B would work 3-1/8" in diameter. Decent quality and definitely cheaper than PIAA's or KC Hilites.
http://www.pilotautomotive.com/foglight2.html
When you told me three of the four that you have went bad that really made me want something else. Thanks prattman I think Ill try the PL-195c driving lights, there less than $60 a pair at AutoZone! They have almost the same dimentions as the Piaas do! Thanks again guy!
Shane,
Sorry to hear about your troubles with your lights. I’ve got 2 driving and 2 fogs by PIAA running right now and I’ve had them for 6 or 7 months now. I run the drivers as my daytime running lights so they are on all the time. So far no issues, but now you’ve got me worried. What’s happened with yours? Are they physically broken from rocks, or what?
Thanks
Bill
Thanks
Bill
are the lights themselves shot? wiring issues? switch problem? bulb issues? i had a deal where the bulb in one of my fogs blew a couple of times and piaa sent me free replacements until problem was resolved.
Shane,
Thanks
Bill
Thanks
Bill
.. I am totally lost on the deal... NOT happy that's for sure...
SHane
I know the wiring's good and the switch.. I believe the lights are sealed so how do I check the bulb's??? I am assuming the lights are shot... How do I get a hold of PIAA? Thanks for any info!! I will keep you guys updated.. I am goona try to pull the lights today or tomorrow...
SHane[/QUOTE]
Shane, keep up to date. Here's the address and number for warranty
http://www.piaa.com/Lamps/PIAAWarranty.html
Thanks
BC
SHane[/QUOTE]
Thanks
BC
SHane
SHane
Thanks
BC[/QUOTE]
Bill you da the man... I am goona give them a call on Monday!!! Thanks... I will definately keep you guys posted!!
edit: I just called them and left a message they are closed until monday!
I've got a set of the 510's also and so far so good, the fit is pretty tight but looks good. I got mine from the 165.00 ebay dude, even with 20.00 shipping was the cheapest I could find. Just be careful, he ended up sending me the amber fog instead of the super white driving, even though the auction said the super white driving, figured I wanted a set of both eventually so I just kept them.
I'll be watching this also about Luv's lights that are T.U.
Nope I have gone through them and there isn't a rock chip at all.. Here's what I have done... My first pair I put each one on the outside holes in the bumper so the outer two are wired together then the next two are wired together(inside ones).. So first two to go bad were the driver's side???? HUH??? they are wired completely seperate?? but the passenger side lights still work.. Then I was out trying to find what was up and turned them on and now just one of them works on the passenger side... No rock chips at all I haven't hit a deer at all again!!
SHane
SHane
matego
34
Jul 2, 2008 12:00 PM
fearthisgoat
Jan 14, 2008 09:24 AM
tx4x4er
25
Jan 17, 2007 09:05 PM
