37s with little lift
Old Aug 28, 2007 | 08:41 PM
OldSmokey's Avatar
Ive got some three inch spacers, and im wanting to run some 37s. My wheels are 9" wide and have a 5 inch bs, but i had to use 1/4 wheels spacers to get them to work so the bs is more like 4 3/4. Would adding longer control armes let me run 37s? As i dont have any rubbing right now with stock control arms and 35s. If so how much longer should i get the control arms over stock, or would i be best to use some adjustable arms?
Thanks Joel
Old Aug 29, 2007 | 07:37 AM
nriver's Avatar
longer control arms would prob help.
some fender trimming may be needed for full suspension travel.
Do some searches on my user name and I have written up much of what i did.
Some others have done it with no fender mods. Your results may vary.
Old Aug 29, 2007 | 07:43 AM
OldSmokey's Avatar
I did your fender mod and i will do the fender trimming if i need to. Anyone know how far you can push your axle forward befrore you start hitting the bumper?
Old Aug 29, 2007 | 08:38 PM
OldSmokey's Avatar
Nriver, how much room do you have between your tires and your front bumper, and how much longer are your control arms over stock? I have alot of room between my tires and my bumber, so if i can move the axle forward about an inch and a half i think everything should work. Is that to far forward, for the trac bar to work, or will it make it bind? Thanks
Old Aug 30, 2007 | 09:00 AM
nriver's Avatar
not sure on teh front clearance. But that has never been a issue.
Most control arms I see are 1/2 longer than stock. DT Pro Fab makes some inexpensive ones. Carli and Kore make some expensive ones.
As far as 1 1/2 inch arms, that may be to far forward, not exactly sure. You may run into more issues with that long of a control arm. I am sure one of the above companies, and more of them can help you out.
Thuren even makes a new cool radius arm kit. Not sure on the effective length vs stock.
Old Aug 30, 2007 | 07:25 PM
OldSmokey's Avatar
Yah, I called Don Thuren, his arms are 3/4 longer. Ill have to call in and ask what the limit is.
Old Aug 30, 2007 | 09:31 PM
Luvnacumns's Avatar
I believe DOn told me he can make then 1" longer!!! But don't quote me for sure.. Me and my silver can buddy's got together tonight!!!
Old Aug 30, 2007 | 09:48 PM
cbrahs's Avatar
influenced posts tonight. we will be able to tell how much he drinks by his spelling!! LOL!!
Old Aug 30, 2007 | 09:52 PM
Dieseljunkie's Avatar
I feel you there Shane! I like my silver can buddies.
Scott
Old Aug 30, 2007 | 09:53 PM
OldSmokey's Avatar
Dons arms are only adjustable on the top are tho? Does anyone know of some bars that are fully adjustable. Im sure i can find some 37s to test fit, if i had adjustable arms i could find out if they would work or not.
Old Aug 30, 2007 | 09:58 PM
Luvnacumns's Avatar
whaaat??LOL!!!
Scott
Yes sir.. The wife works for them so I get'em real cheap and lots of them!!!
I think superlift makes some??? I could have swore UnrulyNFS is runnig them might pm him...
Old Aug 30, 2007 | 10:25 PM
RJOS's Avatar
Nathans twins!! Wife works for the brewery! We thought Wiggs had it good...
Old Aug 31, 2007 | 12:08 AM
Luvnacumns's Avatar
AAh yes to each his own my friend!!!
Old Aug 31, 2007 | 04:36 PM
cbrahs's Avatar
so I can pick up a few cases on my way thru twin this christmas? LOL
Bradleysram
16
Dec 27, 2008 12:45 PM
Pooter
19
Jan 19, 2008 12:37 PM
scarecrow
Apr 7, 2006 02:36 PM
Andrew k
Apr 9, 2005 07:20 AM
gunracer1
33
Jan 12, 2004 09:34 AM
