33x15.50-18 Mickey thompson CLAWS
Old Aug 1, 2008 | 04:11 PM
dieselram_04's Avatar
anybody got any pictures of a set of 15.5" wide tires on their trucks? Just got a smoking deal on a new set of 33x15.50-18 inch claws and 18x10 helo HE 821 just curious what they are gonna look like on my truck. OH by the way i did order a 3" leveling kit so they would clear. (HOPEFULLY) If not ill put them in the classifieds and order a 8" rize lift and 37's!
Old Aug 1, 2008 | 08:14 PM
HighStakes's Avatar
They should look great. I don't have the Claws, but I have the same size Baja ATZ's with a leveling kit. I have no clearance issues even with my fender flares. I just uploaded a close up pic in my gallery, but I can't post until it's processed. Check out my gallery when you get a chance.
Old Aug 1, 2008 | 08:28 PM
chipmonk's Avatar
i think his Claws are 15.50's.
Old Aug 1, 2008 | 08:37 PM
HighStakes's Avatar
Dang.....what a dope, I can't even read. It's been one of those days. Thanks Chipmonk.
Oh well....dieselram, I don't believe those 15.50's will fit with just a leveling kit. Looks like the 8" kit and 37's.
Old Aug 3, 2008 | 09:38 AM
well the leveling kit i ordered is a 3" so im thinkin that may be enough for them to clear. What offset are your weld wheels on your truck? tires should be here by friday ill take pictures and post them up once i get them on. in the mean time ill keep my fingers crossed.
Old Aug 4, 2008 | 03:09 PM
Jfaulkner's Avatar
Muted User
I had a friend that had the MTZ's that were 15.5 wide and they looked good but they rubbed bad even with a huge offset. I had 13.5 claws and they rubbed with a 1" leveling kit but weren't too bad, they only did it just before full lock each direction.
Old Aug 5, 2008 | 05:50 PM
well got word today that the wheels they shipped are a 4.75 BS with -25 offset so im leaning towards aint no way in heck they are fitting under my truck with just a 3" lift up front
Old Aug 5, 2008 | 09:42 PM
03qclb5spd's Avatar
There's a guy around here with a standard cab and 33/15.50 tires and they don't look bad from the side, but from the front or the back or an angle it just looks ridiculous. Even with as far in as they are, they still stick out a ton and look goofy. But, hey....whatever floats your rig.
Old Aug 6, 2008 | 02:13 PM
well a set of fender flares will take care of alot of that for me
Old Aug 6, 2008 | 09:28 PM
03qclb5spd's Avatar
Guy I mentioned has flares too, bushwacker pocket or something...
Old Aug 7, 2008 | 11:02 AM
jwb600's Avatar
im currently running a 325/60/18 on 18 x 10 wheel not sure on backspacing/ offset but they WILL rub on my truck the back side of the tires rub on the black plastic inner fender. I know it follows the road and doesnt drive to exciting either
Old Aug 7, 2008 | 02:14 PM
do you have a leveling kit or are you at stock height? what wheels are you running?
Old Aug 7, 2008 | 03:54 PM
jwb600's Avatar
If you are talking to me I have a 2" leveling kit is all and the wheels are 18 x 10 diamos theres a pic of the exact setup in the classifieds . if you go with a narrow wheel like a 18 x 8.5 you may not have much rubbing at all but it may hard to get a wide tire like what you want mounted on them.
Old Aug 18, 2008 | 11:02 AM
WELL the tires and rims fit wound up making some longer control arms and ordering a trackbar bracket and they fit like a glove. I would need to do some trimming if i wanted to do some wheeling in it but i dont plan on that. I will post some pics up later! Flares are next these things are WIDE and stick out pretty good!
Ricks 2500 CTD
Jan 3, 2008 09:07 AM
gatf4
Oct 14, 2004 07:01 PM
BLUTIC
Sep 19, 2004 08:12 PM
Jeff K
Jun 26, 2003 07:33 AM
